blown head gasket help
I need some help i got a 92 pickup 22re and i had oil in the coolant so i changed the head gasket and took the head to a machine shop got it shaved. Then about a month later it over heater jus barely about normal i thought was weird so i checked the coolant had oil again. So i took the whole engine out got a new head, decked the block, new piston rings while i was in there, bearings, every new gasket, put it all together. A week later it wasnt over heating but i went to check the coolant and had oil again. Anybody had the same problem...help
Welcome to YT!
Take a look at these threads. They may spur an idea:
https://www.yotatech.com/forums/f116...-bolts-219076/
https://www.yotatech.com/forums/f115.../#post52206353
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
FS[PacSouthWest]: FS: A340 transmission and t/case Lancaster Ca
4x4-runner
12-27-2016 01:58 PM
