blown 22re/22rte swap
Old 11-29-2010, 08:39 AM
Tamadrmr26's Avatar
Question blown 22re/22rte swap
driving my 87 4runner (22re) 2 days ago it lost all power and wouldnt idle. i limped to my friends house with it and it started pouring bluish smoke out the exhaust and making a click when giving it throttle while the clutch was out. im thinking i blew a head gasket. hopefully thats it but im not sure. i may be able to trade my dirtbike for an 86 22rte. would this bolt up to my w56 trans no problem? i recently did a marlin crawler heavy duty clutch kit so i dont think the clutch will be a problem. would it even be worth it to get the 22rte since i dont actually know if it will run? it comes with everything like the ecu harness ps pump alternator starter etc.
any advice on the motor swap or on what happened to my motor would be appreciated as i am driving my brothers audi around right now and i feel like a tool in it.
Old 11-29-2010, 08:47 AM
xxxtreme22r's Avatar
blueish smoke is oil. could be head gasket could be rings, but with a click (do you mean maybe a tap or a knock?) I would lean towards a ring and that tap or click that you describe being a piston slap sound. Only way to tell is to do a compression and leakdown check.
could be a few other things as well. But without seeing or hearing what your describing then.....
Old 11-29-2010, 08:55 AM
Tamadrmr26's Avatar
yea, i could smell the oil burning. it could definitly be a knock, i just didnt wanna say it haha. i could only hear it when the clutch was out though. when i depressed the clutch or put it in neutral and revved it a bit it didnt make it.
Old 11-29-2010, 09:04 AM
so basically saying you got a knock when the engine is under load, typical of a piston slap or slight rod knock. Don't think it's a rod knock though since it's burning oil.
I've been wrong before, but in either case, I think the motor would have to come apart. Personally I would stay away from the rte. But that's just me.
Old 11-29-2010, 09:58 AM
Tamadrmr26's Avatar
ahh, i figured it had something to do with it being under load but i didnt know that would make the piston slap louder. thanks for the help. if you know anyone one here whos dropped the 22-rte in place of the 22-re send them my way. i could use some advice.
Old 11-29-2010, 10:07 AM
heh don't know of any, but, if your close enough in NY I might be able to help ya yank the motor.
Old 11-29-2010, 10:33 AM
Tamadrmr26's Avatar
where are you at? i have a good friend who ive done chevy motors with and hed probly give me a hand pulling it and either rebiulding or dropping in the ew one depending on what i decide to do. he doesnt know as much about toyotas/4cylinders and honestly i dont either so if you have any experience with troubleshooting or fine tuning these engines which im sure i'll have to do once i get it in thats where i could use some help
Old 11-29-2010, 12:08 PM
Tamadrmr26's Avatar
ahh, your in wilkes barre didnt see that. im near poughkeepsie. thats pretty far. thanks for the offer though
Old 11-29-2010, 01:00 PM
heh, I know where Poughkeepsie is, it's about 3 and a half hours from me, ex wife lives in Hopewell Jct. I had to go to Poughkeepsie for my child support hearings haha.
Old 11-29-2010, 03:06 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
An RTE is just a de-compressed RE with different electronics and computers.
It has a junk stock turbo, the CT20, that you're immediately better off just throwing in the junk pile.
You have NO idea what you're in for.
It's not particularly even a good engine.
Old 11-29-2010, 03:37 PM
Tamadrmr26's Avatar
haha, i live a couple of miles from hopewell. still cant decide what i wanna do. i might just sell the dirtbike so i can rebuild the 22-re and do some aftermarket work to it. the turbo motor would be cool but i dont really wanna deal with it. where can i get a good rebuild kit? i'll probly do a cam too. any advice there?
Old 11-29-2010, 03:54 PM
Tamadrmr26's Avatar
engnbldr kit seems to be what everyone recomends. how are the camshafts that he sells?
Old 11-29-2010, 04:03 PM
I got the 268 no complaints so far with mine.
Old 11-29-2010, 04:09 PM
Tamadrmr26's Avatar
how much of a difference did it make?
Old 11-29-2010, 04:36 PM
couldn't say it was done during a full rebuild.
Old 11-29-2010, 05:26 PM
Whoa there... Cams don't work too well with EFI's.
Unless its specifically a cam for EFI.
Old 11-29-2010, 05:30 PM
EB advertises his cams for both EFI and carb'd doesn't he?
I know the stock grinds won't work well with each other though.
Old 11-29-2010, 05:36 PM
sebastianholmes's Avatar
yea the EB cams are good with carb or EFI motors, i want the 261, but i gotta save up! lol
Old 11-29-2010, 06:04 PM
this is because the higher the overlap the lower the vacuum tends to become correct? Also typically what causes a loping idle.
kinda like these beasts:
http://www.youtube.com/watch?v=--MM4uUrfSw
http://www.youtube.com/watch?v=93H00gilGSs
Old 11-29-2010, 07:27 PM
Not that I looked, but all I saw was "85-95".
Coincidentally the deck heights, not specifically EFI.
And good posting on the vids. If you can live with that lope, more power to ya
Quick Reply: blown 22re/22rte swap
