Blinker issue odd citation
Old 08-19-2015, 02:59 PM
89Yota4x4RatTruck's Avatar
I have a 1989 Toyota pickup 4x4 4cyclinder, when I got the truck a week ago the blinkers didn't work no click no light driving It home from a friends after brake work the blinkers worked but fast blinks (like a light was out) then the next day nothing so I replaced the blinker relay and no luck really need some pointers here guys!
Old 08-19-2015, 11:33 PM
wyoming9's Avatar
Red face
All the turn signal lights work you just have the Hyper flash??
Does this have LED bulbs or lights ?? If this is the case you need a flasher made for the LED lights .
Old 08-20-2015, 12:52 AM
Staff
Terrys87's Avatar
Check the sockets and the bulb contacts are clean. The Return wire has needed cleaned or replaced on mine before. Usually a little corrision some where in the assembly.
Old 08-20-2015, 02:37 AM
Regular bulbs no lights at all at this point I've checked all weird and grounds and I am now going to remove the lever and switch from the steering colum
Old 08-20-2015, 10:24 AM
wyoming9's Avatar
Red face
Why does every one take things apart that would be the last thing to look at??
You should check for voltage at the plugs before the lights.
Maybe all the bulbs are burnt out??
Checked that the fuse is tight in the socket??
Checked the fuse is not open??
Do the 4 Way flashers work??
Old 08-23-2015, 04:05 AM
AKHeathen's Avatar
turn the hazards on and off and try again. intermittent stuff like that in my audi would be moisture related, indicating a poor contact.
LosPatosDelSur
23
03-12-2021 03:08 AM
DeathCougar
04-01-2018 11:29 PM
ghostmoney
01-28-2018 11:42 AM
Team420
12-30-2015 01:31 PM
terminator
07-27-2015 07:13 PM
Quick Reply: Blinker issue odd citation
