| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Blew Up the Front Dif!!!
#2 (permalink) |
Check the axle code on the door.
__________________
1985 toyota 2wd truck 2in body lift 28in m/t's -sold 1981 toyota sr5 truck 4in lift 33x12.5 procomp m/ts- sold 1986 toyota 4runner 3in suspension lift 3 body lift, 35x15.5 tsl sx's welded rear -sold red1986 toyota 4Runner Turbo barely running-sold 1974 toyota fj40 2in lift conn-ferr long rang fuel tank, 33in tsl's, chevy 350 4spd-sold 1994 toyota 4runner manual hub swap, FZJ80 rears, 4crawler 1.5in BJ spacer, 5.29's, spooled rear, lockright front, custom body work by rock |
#3 (permalink) | ||
5sp's and some auto's came with 4.56's. I know my auto has factory 4.56's.
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's |
#4 (permalink) |
I believe it's going to depend on what tire-size was factory...
call up a dealership with the vin; thet'll tell you everything you could possibly want to know
__________________
91 PU, 4wd, manual, 22re, .30-over, engnbldr RV head and 261 cam, MC 1200lbs clutch, misc LCE, engnbldr, and MC parts and HW, Pacesetter header and exhaust kit, Rancho UCA's , 4Crawler 1" diff and sway bar drop and 1.5" BJ spacers, WabFab 3.5" shackles, 31x10.5 pavement-pounding ATs on ProComp Extreme Alloys, misc SR5 interior goodies swapped in, 1000watt stereo system MySpace |
#5 (permalink) |
Mine came with 4.10's stock if you need one to replce the ld one I have a full A.D.D. frm a 90 cheap
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#6 (permalink) | |
Staff
Wish I had a dollar for everytime I've posted this link http://www.off-road.com/trucks4x4/ar....jsp?id=274535
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
#7 (permalink) |
Thanks alot and I will check the door or call a dealer tommorow...... Pics tommorow also.....
#8 (permalink) |
I have a 4.56 ADD IFS axle also for sale if you need it. I'm curious - what exactly were you doing when it broke? Usually the CV joints give out long before the axle can be damaged.
__________________
"Turtle" - Green 94 4Runner Looks like one and about as fast JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear. |
#10 (permalink) | |
Quote:
Those codes aren't worth a damn if they're not right. I don't ever trust them, its better to check for yourself instead of assuming, throwing some parts in, and then blowing up.
#11 (permalink) |
I have seen the chart make a mistake too.
You can get right to the gear ratio by counting the spins on the driveshaft/vs/tire. 4.x turns of the driveshaft to 1 turn on the wheel... done it several times.
__________________
85, 87 (SAS), 88 (on loan), 96 4Runners, all males... 03 Town and Country... female CLIK4PIX |
#12 (permalink) |
wish I could help, you and I are in the same boat, I'll watch and learn; my front diff has a gaping hole in it, so no 4WD for me right now
#13 (permalink) |
__________________
93 sr5 v6 auto, 4x4 Photos http://s866.photobucket.com/albums/a...albumview=grid there are quite some attractive ladies on here with Toys. (compliments of ironmike) ifsc 3(.0) http://tlca.org www.of4wd.com www.sontt.com |
#14 (permalink) |
oh wow, that link just gave me the part number for the instrument cluster bulbs/sockets I had been looking for.
Thanks!
__________________
'87 T4R Deluxe, mall crawler every non-SR5 option installed (sans AT), as well as: * Cruise Control (dealer installed) * Michelin LTX A/T2 31s on 1st-gen alloy rims * SmittyBilt granny step bar * SR5 Instrument Cluster |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Blew my front Trail-Gear driveline. | swapped89 | Solid Axle Swaps, All Years | 3 | 12-09-2008 05:02 PM |
| Re-Gearing Front Axle, What does it take to remove the Front Dif? | grant526 | 84-85 Trucks & 4Runners | 10 | 02-20-2008 12:52 PM |
| front IFS dif w/4.88 & other parts | Gonzo4Runner | The Classifieds GraveYard | 5 | 09-06-2007 02:39 PM |
| Front Dif. Breather....where is it? | YM13 | Offroad Tech | 4 | 11-05-2006 06:49 PM |
