Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
#923
Bleeder if i may, where did you get the bracketry that allowed you to clear up the mess thats atop the valve cover, Thanks and great pics and build info you have there.
#924
I lost a lot of the mess when I got rid of the EGR valve; that removed one VCV, and the little plastic disc-shaped thingy that clipped into the metal bracket bolted onto the top-rear of the valve cover. The only other two things up there, the VCV for the AC idle up and the one for the fuel pressure regulator, I just rerouted the new vacuum lines to the back of the upper intake manifold, and mounted them using the same bolts that hold the EGR block-off plate to the back of the upper intake.
As far as those brackets holding the vacuum lines in place on the side of the upper intake, those are actually spark plug wire holders, for a small block chevy, that I just had lying around in my tool box
http://www.mr-gasket.com/ProductDeta...minselection=3
#926
hey bleeder i have a question lol i just got a pacesetter header on mt 22re and i have some really loud exhaust leak sounds? like i know i had an exhaust leak between the down pipe and manifold and i thought with the header it would delete the exhaust ting sound? nope it's worse. my dad had a shop put it on and it looks like they did everything right but all i get is a hell of a ruckes from my header???? lol oyah and just like yours the paint is already pealing lol. so i guess im asking you if i should question the shop or is this header just super loud? sounds good coming out the tail pipe though and i noticed some power gains
#933
honestly, the PaceSetter header is exactly as it costs... cheap...
I mean, it serves its purpsoe I guess, but mine leaks like crazy right now, and I've gone though 4 or 5 head-mounting gaskets now...
I'm going to replace it with a thorley tri-Y shortly
#934
Bleeder, got a question for ya, im getting ready to buy a block and start a motor build, been looking at alot of the threads regarding this and saw somewhere along the line that a 91 22re block may be a little differant then an 87 re block, it was stated that there are some sensors that plug into the wiring harness and they maybe a little differant. Can you shed any light on this for me?
#935
Wiring harnesses change from 88 to 89. I found this out the hard way. I've got an 88 4Runner. Bought an 89 pickup motor.
During the rebuild I sent the injectors from the 89 out to be flow tested. Afterwards when I was assembling the motor, I realized they wouldnt plug into the harness in my truck
#936
OUCH.
Good info.
#938
Oh and next time you do this (300,000 miles from now) go with blue vac hose. It'll look flat crazy!
#939
awesome ... i was supposed to get the LC stainless header but my dad ordered the pacesetter. didnt complain because i got it for christmas lol so no complaining there but, i didnt expect it to leak worse than before, so i guess i should leave my dad out of things involving my yota lol.
#940
