BJ spacers installed (pic)
Old 01-15-2013, 02:11 PM
oldblue's Avatar
Tell me what you think. I'm stoked about the outcome, i got the perfect stance i was looking for. Didn't even touch the torsion bars. Still have to install the diff drop, but i'll do that at work and not on my back. Took the sway bar off instead of lowering it. I just need some longer shocks. What would ya'll recomend for shocks? Wish i had money for new wheels... I also added a picture of when it was stock, small tires and fresh wax job!
Attached Thumbnails BJ spacers installed (pic)-lifted3.jpg   BJ spacers installed (pic)-clean.jpg
Old 01-15-2013, 05:36 PM
toyota4x4907's Avatar
Beautiful! Anymore pictures? She looks very clean!
Old 01-15-2013, 07:51 PM
racersg's Avatar
That looks nice! Great job.
Old 01-15-2013, 08:14 PM
Toyota~Boy's Avatar
I used 1992 ford bronco front shocks and 87 Chevrolet truck rear shocks. The bronco shocks are a direct bolt on and are perfect for the BJ spacers. The Chevrolet shocks are slightly different. You must make your own bushing for the lower mount of the shocks. By the way I'm using Monroe shocks from my local NAPA. Costed around 50-70 bucks for all four and seems perfect.
Old 01-16-2013, 02:32 AM
oldblue's Avatar
Interesting, i like the price!! Did you have to make bushings for the front and rear, or just rear? and what did you use to make them?? I might have to try this, much better than $200 plus on rancho's
Old 01-16-2013, 02:33 AM
oldblue's Avatar
It's been crappy and rainy here, so no other pics right now. I'll get some more good ones up soon. There is talk of snow in georgia tomorrow!!!!!! Maybe i'll get some 1" Georgia blizzard pictures!!
Old 01-16-2013, 07:49 AM
Toyota~Boy's Avatar
Only the rear will need modified. I just used a knife and cut the original bushing until it was large enough to fit over my bolt. If you look at the specs of those shocks they are perfect for the BJ spacer lift. They have just the right amount of travel.
Old 01-16-2013, 08:03 AM
Yamiryder's Avatar
I'm interested in this. I just put on BJ spacers and need new front shocks for sure. Do the bronco shocks come with new hardware that works? I'm in PA and rust is a real issue. Also, are these for a full size bronco or bronco II??
Old 01-16-2013, 08:13 AM
Toyota~Boy's Avatar
I'm in WV man rust is same here. The shocks are for full size bronco. And yes mine came with all hardware
Old 01-16-2013, 12:30 PM
Yamiryder's Avatar
Sweet. I might try that. Better than extended shocks or spacers.
Old 01-16-2013, 03:24 PM
kawasakilewis's Avatar
i work at napa i looked at the specs for the bronco shocks and they are almost 3 inches longer when they are fully compressed. you do not need 1.5 extended shocks for 1.5 spacers becase the distance is not equivilant because the spacers are out at the end of the control arm and the shock isnt. not saying it would not work but i would be careful especially if you have low-pro bumpstops or something because you may overcompress or turn your shock into a pop can.
Old 01-16-2013, 04:35 PM
can you post up some shocks and part #s for him ?
Old 01-16-2013, 07:28 PM
truckmike26's Avatar
Clean truck.
Old 01-17-2013, 04:56 AM
What do you need
Old 01-17-2013, 05:54 AM
Front shocks for bj lift
Old 01-17-2013, 06:27 AM
i tried looking them up before and theres like nothng that would be good. i would honestly just usevthe spacers because its not that big of a difference
Old 01-17-2013, 06:28 AM
Toyota~Boy's Avatar
I have had no issues. My shocks have been on for over a year and yet to this day I have had absolutely no problems. So that's just my opinion. It's your guys truck. You make your own decisions based off the info you gather here lol.
Old 01-17-2013, 06:31 AM
Swimmerboy2112's Avatar
You can get the longer shocks from some of the vendors on here. I used ProComp ES9000's when I did my BJ spacer and add a leaf lift.
Old 01-17-2013, 08:45 AM
22R4EVR's Avatar
I would recommend the bilstein 5100 http://www.shockwarehouse.com
work great for jumping around and give you that extra travel when you need it and make sure you relax your torsion bar to get that smoother ride feel now that you have the height.
09-04-2015 09:27 AM
Scotto6591
09-01-2015 03:24 PM
terminator
07-27-2015 07:13 PM
Yotoder865
07-09-2015 07:51 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: BJ spacers installed (pic)
