BJ spacer ?
Old 01-22-2013, 02:04 PM
BJ spacer ?
i picked up a pair of 1.5" with out the hardware , what size are the nuts and bolts ?
thanks
Old 01-22-2013, 05:18 PM
MudHippy's Avatar
~1.5" longer than stock.
Old 01-22-2013, 06:18 PM
What is stock size ? And what strength rating ?
Old 01-23-2013, 06:40 AM
MudHippy's Avatar
I don't know the answer to either of those questions.
But I did find the answer to the first one.
Hardware consists of M8-1.25x80mm class 12.9 socket cap-screws, class 10.9 steel nuts, stainless steel nylon locking nuts, and flat washers.
http://4crawler.com/4x4/ForSale/Ball...tml#DISCLAIMER
To order a set of them see the link below:
http://4crawler.com/4x4/ForSale/Ball...er.shtml#FAQ13
Old 01-23-2013, 10:12 AM
93Xtra-Cab's Avatar
I know they're M8 bolts with a 1.25 pitch. They need to be class 10.9 or 12.9 (10.9 is roughly the metric equivalent of the standard Grade 8). Don't use anything less when it comes to suspension stuff. As for length, do as MudHippy said: simply add 1.5" to the existing bolt length.
EDIT: Whoops! I need start reading better. Mud Hippy already came back and answered it.
EDIT 2: You might want to consider buying the bolts, nuts, and washers from your nearest ACE Hardware. All together, it MIGHT be more than $20, but you also have to factor in shipping costs and the time you have to wait for them to be shipped. Just a thought.
EDIT 3: Don't bother with Home Depot or Lowes. I've heard that they don't carry higher grade bolts. I don't know for sure because I try not to go there because they're stupid.
4x4YOTA
08-23-2016 09:08 AM
89YodaRunner
09-30-2015 02:18 PM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
crash813
09-27-2015 07:15 AM
Quick Reply: BJ spacer ?
