Best windshield wipers?!
If your like me, you want to purchase a quality product. What is the best windshield wiper you can buy for a toyota pu/4runner? Mine are seriously shot and in need of replacement.
The PO of my '95 sprung for some sort of silicone blades, I don't know what brand, but they work well and are showing no degradation after two hot AZ summers so far. Probably were'nt cheap.
So far, this is what I see fit.
(rain-x winshield clean kit with windshield treatment)
http://shop.advanceautoparts.com/p/r...ntent=10285742
(rain-x latitude wiper)
http://www.carid.com/1984-toyota-4ru...mJWRoCGLPw_wcB
Rain-X is good. You can even get by w/o wipers in a pinch if you have rain-xed your windshield.
Wow you people in Sunny California have it easy.
I am lucky if I get 2 months out of the drivers side wiper blade then it gets cleaned and moved to the right side
I do run the Rain-X washer fluid I am happy with that.
Now I am using Anco Winter blades.
I really have never found wiper blades that work much better then any others.
In this part of the country any how.
I tried a bunch over the years.
Now just get what Napa has.
I've been driving in the Pacific Northwest for 30 years. It does rain alot here and at times it seems like I might want to help Noah build another boat.
One of the most important things is to have a good UNgrooved windshield.
Sure most people clean their windshield, but they fail to clean the wipers. If there's anything stuck to them it gets drug over the same spot repeatedly wearing small grooves into the windshield. Fine dirt and bird poop are abrasives and might as well be sandpaper. Drag that on any surface long enough and I guarantee there will be scratches and grooves.
Wipers should actually be replaced a couple times a year because they get impregnated with fine dirt and bird poop not to mention they slowly start to harden up. All of those things contribute to scratched glass hampering your vision.
Treating your windshield with Rain X or Aquapel makes the water bead and flow right off when you're carrying some speed. For me both treatments have caused the wipers to have a bit of a jerk/stutter/skipping motion when freshly applied. Almost every car I've been in that has had those windshield treatments properly applied does that for a while. Eventually it will stop but it can become irritating.
I haven't used the Rain-X De-Icer Washer Fluid so I won't comment on it but I have used the All Season formula.
"Removes light snow and frost", not in my opinion.
It's ok, but I found it really doesn't cut the oil/road film that gets thrown onto the windshield. If you can't get rid of that stuff say goodby your vision.
This winter I tried 20/10 All Season washer fluid. I don't know what took me so long to try it because it's made near me and it's been around since I was a kid. I mixed it following the instructions and found it works pretty good for cutting the oils and road film. It's not advertised as a de-icer.
Another good one for cutting oils and road film is called 1Z Kristall Klar Washer Fluid Concentrate. Follow the instructions when mixing or make it a little thinner. Read some of the reviews of it on Amazon, it can be a little sudsy and it freezes at about 30 degrees so it's not the best thing to use in the winter.
bryan34w
12
09-30-2015 02:50 PM
PNW94Runner
09-29-2015 02:55 PM
