Best Valve Cover Gasket Seal? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-04-2007, 04:04 PM   #1
I have my valve covers removed and plan to pick-up new gaskets tomorrow. What is best sealant to use on the valve covers in the corners around the cam bearing covers?
Thanks for the help in advance!!
BusterMcC is offline   Reply With Quote
Old 03-04-2007, 04:12 PM   #2
ChickenLover's Avatar
I've always used the regular orange RTV. It's available at every auto parts store, and walmart. It works just fine.
ChickenLover is offline   Reply With Quote
Old 03-04-2007, 04:24 PM   #3
I've always used permatex's ultra grey RTV for just about any cover (oil pan, timing cover, valve cover, ect). Found just about anywhere for like $3 for a 3.5oz tube
SwampThing is offline   Reply With Quote
Old 03-04-2007, 05:21 PM   #4
JEBSR5's Avatar
As others have said, any RTV should be OK, I'm partial to the ultra gray Permatex also. FIPG is probably best, but not as available as RTV.
JEBSR5 is offline   Reply With Quote
Old 03-04-2007, 06:03 PM   #5
GSGALLANT's Avatar
"The right stuff" by permatex is an excellent product, endorsed by many on here. I use it everywhere that Toyota specifies any FIGP on both my 1993 and 2002 4R's. There is virtually no "cure time" required before re-filling your systems, and it is compatible with all fluids in your vehicle.
GSGALLANT is offline   Reply With Quote
Old 03-05-2007, 07:28 AM   #6
WillRadford's Avatar
I think more important than the type you use, is where you put it. Put it around the whole gasket. I read on a thread here from someone to do that and it solved my problem. Put plenty of it all around the whole gasket and you wont have any problems if the mating surface is clean.
WillRadford is offline   Reply With Quote
Old 03-06-2007, 04:24 AM   #7
TNRabbit's Avatar
I just used plain rubber gasket no sealant; no issues.
TNRabbit is offline   Reply With Quote
Please help! smthwsn357 86-95 Trucks & 4Runners 7 04-11-2016 06:22 AM
Its beginning to look a lot like a head gasket?! (overheating) the1998sr5 95.5-2004 Tacomas & 96-2002 4Runners 13 01-11-2016 10:55 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Leaking Rear Tranny Seal and Top Tranny Gasket Iceman4193 86-95 Trucks & 4Runners 3 07-15-2015 05:48 PM
22r leaking 87blyota 86-95 Trucks & 4Runners 3 07-10-2015 05:31 AM
Tags
2002, 4runner, cam, cover, covers, gasket, gaskets, grey, orange, permatex, rtv, rubber, sealant, sealer, sears, ultra, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
