Best price on gears
Old 07-17-2014, 04:58 PM
jordanhere123's Avatar
Best price on gears
Who has the best price on front and rear 4.88 ring and pinion gears and the master install kit? I have a 94 toyota pickup 22re
Old 07-17-2014, 05:37 PM
Yotard's Avatar
I did 4.88s this spring in my v6 and my research concluded that motive gear was the cheapest gear and Japanese setup kit that was still highly recommended
Old 07-17-2014, 05:41 PM
How much was the install kit for front and rear? Do you have a link to this?
Yotard's Avatar
Getting a stock 4.88 front ifs diff is cheaper than regearing your front especially since it doesn't see the wear that rear diffs get. I got a used front diff for 300 bucks shipped from this site. You can't get a ring and pinion with a setup kit for that price. I added spartan lockers at the same time too. I had the rear built but did the front myself
Old 07-17-2014, 05:43 PM
Yotard's Avatar
I bought the ring and pinion from jegs for 170 and the setup kit for 200 from them with free shipping.
Old 07-17-2014, 05:57 PM
I thought about doing that. Any front diff from a 4 runner will work? I found one with an automatic disconnect the guy said I can just swap the axle stub from mine and it will work.
Also is the stock front diff from mine worth anything?
What years of 4 runners came with the 4.88 and will work with my pickup?
Old 07-17-2014, 06:05 PM
JasonYota's Avatar
I believe the 3.0 auto 4wd 4runners. All 4.88's have ADD. Also note that the stock 4.88's are weaker than aftermarket 4.88's due to the off set. Can someone confirm if this applies to front 7.5 4.88's or just the rear 4.88's?
Old 07-17-2014, 06:24 PM
I found some on eBay for a good deal shipped they seem. I can also check some local junk yards. I just want to make sure the ADD will be able to be swapped with my Non ADD part from my diff now. 94 pickup 22re 5 speed I have
Old 07-17-2014, 06:43 PM
Yotard's Avatar
That only applies to rear stock gears not front.
Not all 4.88s are ADD either. I know this because I bought a non add diff with 4.88 gears and I bored out the carrier and pressed in the needle bearings to make it the same as the add axle. However, if you have a non add setup an add carrier will fit just fine. In fact you can use the non add in an add setup but you won't have the needle bearings which is better. I have a whole thread about this work.
Old 07-17-2014, 07:56 PM
Thanks for the quick responses. I know what I am doing for the front. Will a stock 4.88 rear diff from a 4 runner work with my pickup or no?
Old 07-17-2014, 08:01 PM
Yotard's Avatar
Yes 7.5 IFS diffs are interchangeable
Old 07-17-2014, 08:08 PM
I meant the rear. I forgot that in what I posted
Old 07-17-2014, 08:53 PM
rokblok's Avatar
Yes. Rears will swap. 4wd to 4wd. Rears are 8".
Old 07-18-2014, 04:27 AM
JasonYota's Avatar
That only applies to rear stock gears not front. Not all 4.88s are ADD either. I know this because I bought a non add diff with 4.88 gears and I bored out the carrier and pressed in the needle bearings to make it the same as the add axle. However, if you have a non add setup an add carrier will fit just fine. In fact you can use the non add in an add setup but you won't have the needle bearings which is better. I have a whole thread about this work.
Thanks for clearing that up
Old 07-18-2014, 09:24 AM
Apprently there might already be 4.88s in the truck that I was unaware about. Just checked by spinning the front driveshaft and looking at the axle. The driveshaft spins just under 5 times.
Old 07-18-2014, 10:54 AM
Yotard's Avatar
Lucky! Check your axle code in the door G144 is stock 4.88s
Old 07-18-2014, 04:36 PM
cobolt23's Avatar
The trucks with 31" tires with autos got the 4:88. The rear third member is useless for an upgrade. It will only fit the stock 4:88. I don't think you can even put a locker in it, but am not sure of that.
Old 07-19-2014, 04:23 AM
JasonYota's Avatar
Looked at ZUK's website last night. Gear installs.com he installed a supra limited slip in a factory 4.88 3rd. That would mean the carriers will swap over. So you can install a full locker or a lunch box locker in a factory 4.88 3rd.
polo451
13
11-20-2016 07:49 PM
jerusry
10-19-2015 05:28 PM
vanion2
07-29-2015 06:17 PM
Athansinis
07-27-2015 08:38 AM
SMOD
07-23-2015 10:29 PM
Quick Reply: Best price on gears
