Best method 22re valve seals
Old 09-12-2010, 10:34 AM
Flash319's Avatar
I am going to do the valve seals on my 22re and wonder what experience others have had doing these. I am going to try the rope trick but has anyone had luck with another way? comp air, rags....
Old 09-12-2010, 11:06 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
delete
Old 09-12-2010, 11:37 AM
RustBucket's Avatar
I used the rope trick on a 1.5L tercel engine once: OHC, side mount spark plug to very similar. It worked fine.
Old 09-12-2010, 11:58 AM
Flash319's Avatar
Originally Posted by tried4x2signN
have the machine shop do it...
...That's the best method I know of
Maybe I can get them to change the oil to.........................
Old 09-14-2010, 04:52 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Bring the vasoline. Walgreens is running special, btw.
Old 09-14-2010, 04:53 PM
thook's Avatar
Oh, and a real answer......
I've never done the seals myself. So, no help here. Just more sarcasm.....
Old 09-14-2010, 04:59 PM
delete...
Dang I miss-read this whole thing...
My goof, I thought you said guides not seals...
DEERRRRRRRRRRRRRRR!
Yes, run a shoe lace in the spark plug hole and run that piston up to TDC...
Then using a spring compressor remove the valve spring...
Dang, again, my bad...
Old 09-14-2010, 06:28 PM
Flash319's Avatar
delete...
DEERRRRRRRRRRRRRRR!
I figured a bit to much green.....1300 posts and that was your bright idea.
Shoe lace eh, never heard of that. That might be easier to handle then the rope.
Old 09-14-2010, 07:21 PM
yoterr's Avatar
i pulled my head and fubared one of the valves and had a machine shop reseat all the valves with new seals and one new valve for 120 bucks worth it to me that way all the valves seat properly buttt i had it off already too...yeah rope trick sounds worth it
Old 09-14-2010, 07:29 PM
The compressed air thing scares me b/c it seems like the slightest movement or loss of seal on the valve and it would fall in.
The shoelace method is cheap, reliable and requires no special tools.
coleypull15
11-03-2015 07:41 AM
09-04-2015 09:27 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: Best method 22re valve seals
