belt diagram
Old 12-10-2009, 07:38 AM
tktmsa's Avatar
belt diagram
Hit 8 below zero (F) last night, one of my belts snapped as I was almost home, my FSM download is a mess after some computer trouble can any one post a link or diagram on what goes where (3.slow)- Thanks! burrrrrrrrrr
Old 12-10-2009, 08:41 AM
Tubbyfatty's Avatar
The power steering belt is the first one you can get at when everything is on. It goes from the pump to the fan bracket pulley then to the crank.
Next is the AC belt, if yo uhave it. It just goes to the crank from the AC.
Then the belt furthest back is the alt, i think it goes to the crank and back.
P/S - fan pulley - crank
AC - small AC adjuster pulley - crank
Alt - crank
Old 12-10-2009, 09:01 AM
tktmsa's Avatar
Thanks Tub,
Can you point me to the tensioners for each belt ?
Do I have to remove the fan to get the belts on?
Any visuals around? The FSM and my Haynes manual are wonderfully vague.
Old 12-10-2009, 09:05 AM
Ardent's Avatar
the PS pump is the tensioner for its belt.
The Alt is the tensioner for its belt.
The AC has a tensioner pulley. Its the lowest pulley on the front of the engine and has an adjustment bolt on it. You have to loosen the bolt that goes through the pulley then you can adjust it.
Old 12-10-2009, 12:17 PM
tktmsa's Avatar
getting the PS pulley to move is done how ?
Old 12-10-2009, 01:12 PM
tktmsa's Avatar
got them all on, I have a major squeal happening, fan is not spinning, see new thread = Major Squeal.
zytra
01-24-2019 03:16 PM
primordialbeast117
12-19-2015 12:23 PM
moparbay
10-06-2015 09:24 AM
EVars
09-29-2015 02:06 PM
gentry
09-28-2015 06:16 AM
Quick Reply: belt diagram
