battery/wiring/starting issue please help
Old 12-29-2013, 06:19 PM
kawasakilewis's Avatar
hi all, 85 xtracab, 22re. got in today it a parking lot after i just got done driving it, as soon as i hit my key, i lost all power, clock reset and everything, if i got out and messed with the terminals i could get power back but as soon as i hit the key everything would dim, then eventually i got enough power that it would click the starter solenoid but then loose almost all power every time i hit the key. put jumper cables on it, fired right up. then i drove it to the parts store and threw a new battery in, same thing, kept losing power. throw a set of jumper cables on it, fires right up and drove it home. got home, cant start it again but if you put jumper cables to it itll start. my battery tested 12.64 volts and 730cca, and i tried a brand new battery in it at the parts store, the only way it starts is with jumper cables on it. i am stumped, anyone got any ideas?
Old 12-29-2013, 07:21 PM
BigBluePile's Avatar
Bad ground?
Old 12-29-2013, 09:38 PM
tweek's Avatar
Clean and check your battery terminals!
Old 12-29-2013, 10:21 PM
wyoming9's Avatar
Red face
I have to wonder just what your battery terminals look like.
It sure sounds like your terminals are not making contact with what ever battery you install.
Clean the inside of the terminals or maybe replace.
Time to upgrade the ground cables as well
The Fact your battery measured good pretty much says it is in the battery terminals or a bad ground will also do this.
Are you attaching the jumper ground to the engine??
Old 12-30-2013, 03:24 AM
my terminals are like brand new, still have the fancy paint on the outside and clean on the inside, ill try cleaning them up tonight and checking out my ground.
Old 12-30-2013, 08:17 AM
daved5150's Avatar
x3 on possible ground. Check connection at starter and cable itself. You're in PA so there's possibly gotta be some corrosion somewhere. Keep us posted.
Old 12-30-2013, 08:30 AM
i realized i only have a ground to the body, im going to get a ground wire to run to the block tonigh ill let you know if that helps
Old 12-30-2013, 01:31 PM
wyoming9's Avatar
Red face
Cold Temps that will cause that to happen.
I see it way to often.
Even a ground to the frame and inner fender will cause a no crank issue in the cold.
Good clean connection to the block.
I have run ground wires to the bottom starter bolt at times.
Old 12-30-2013, 02:07 PM
FIXED IT! the secondary ground wire to the block made her fire right up! thanks guys!
Old 12-30-2013, 04:07 PM
daved5150's Avatar
Good to hear buddy! That's awesome. Was the block ground gone or bad?
Old 12-30-2013, 04:14 PM
it was m.i.a. haha
Old 12-30-2013, 04:27 PM
daved5150's Avatar
Was it a PO hack job or you take out? It never hurts to check your grounds when the electrical bugs show up.
Old 12-30-2013, 04:34 PM
mustof been a PO hack job b
Old 12-30-2013, 07:28 PM
Yay!
Old 12-30-2013, 11:35 PM
wyoming9's Avatar
Red face
Funny how some vehicles can have good cranking voltage with poor grounds till it gets colder.
Old 12-31-2013, 08:51 PM
RAD4Runner's Avatar
Definitely.
And the starter needs the most current, hence least resistance, on the block so block ground as close to the starter as possible is best.
I'm in planning phase of ground and alt-battery wire upgrade, as we speak. I see no issues at present because I cleaned all my connections but I like robust so wanna do this.
If owner measures with negative probe to block and positive to starter solenoid screw-on terminal, they would catch the bad block ground. However, most people measure battery post. That would read good, even IF, and especially IF, connections are bad because they're basically reading voltage of batt with no load.
Old 01-01-2014, 12:50 AM
wyoming9's Avatar
Red face
Truth be told there is quite a lot of copper and converter theft in that part of the Commonwealth .
Seems someone needed more then one day a year in the spotlight. Getting a taste of fame was just to much for the little guy.
Now to support his lavish lifestyle poor Phil has turned to a life of crime!!
bigjstang
08-25-2021 12:41 AM
nvdesertrunner
05-11-2020 08:18 PM
crammit442
7
11-29-2017 12:30 PM
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
Quick Reply: battery/wiring/starting issue please help
