Battery light
Old 11-23-2009, 02:37 PM
fireman1102's Avatar
Battery light
I have an '86 Toyota pickup (22R). The battery light came on so I did the basics, checked connections and had the alternator checked. Turns out the alternator was going so I replaced it. However, the battery light is still on. Connections are good and clean, belt is tight, wires are in good shape. Any suggestions?
Old 11-23-2009, 05:57 PM
bugs1961's Avatar
I don't have a wiring diagram for your truck but I suspect the ALT fuse or fusible link is blown. Disconnect the battery and check for continuity between the alternator and the fuse box. If that's good, there may be a problem in one of the alternator wires. You will need a wiring diagram to identify the wires and their routing.
Old 11-23-2009, 05:59 PM
wd21_sr5's Avatar
Defective alt.? I've seen it.
Old 11-23-2009, 06:04 PM
whokrz's Avatar
I got a defective alternator at napa. It lasted me from Roseburg Or. to Browns Camp were it died. I returned it to napa and this one has lasted me 2yrs so far.
Did you have the old alternator checked to see if it was bad?
Yota.Jay
28
10-22-2015 01:08 PM
AkitaDog
09-01-2015 08:05 AM
mluz013
07-24-2015 12:31 PM
Sandman
07-14-2015 12:36 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Battery light
