Sign in using an external account
| 86-95 Trucks & 4Runners 2nd/3rd gen pickups, and 1st/2nd gen 4Runners with IFS |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
battery cable burning
#2 (permalink) |
Personal
Sales Rating: (0)
when u are saying it burned out what size wire are u using? did u get all the grounds put back on when u installed the motor, one on the back firewall to motor and one on driver side fender to heads, and the ground from battery to fender wall and frame.
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
both wires are the same. the first one that burnt out was the one i used before i put in the rebuilt motor. as far as grounds,... I'm gonna do a double check making sure i got all of them...
#4 (permalink) |
Personal
Sales Rating: (0)
Well what size cable are you using for the grounds.
You mean to say it got so hot it melted the insulation off!! The whole length of the ground cable. Loose connections can cause heat. Something for sure is not correct . If this happened best to look at the ground for the ECU that could also be cooked. Pictures would be a big help
| Tags |
| batery, battery, burn, burned, burning, burnt, cable, cables, ground, hot, negative, post, scion, smoking, terminal, toyota, yotatech |
