battery and brake light on
92 4runner battery and brake light are on,alternator is brandy new. but sometimes the lights flash sometimes its off sometimes its always on..
as well as im having a random minor misfire, but not throwing any codes?
Check and clean grounds...
If good, start checking to see if the alt. is puttting out 14.4 volts to the battery with the truck running. If not...
The new alt is bad or you have a wiring issue. Start checking wires to make sure nothing is split or gounding on any metal.
ashersullivan88yota
01-18-2022 05:37 PM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
