battery
battery
i went to start my truck this morning and i heard some popping noise from my battery and now my truck wont start and it shows that the batter is low like beyond the point to where its enough juice to crank the starter so i put it on the charger and now the buzzer that comes on when you open the door comes on it makes a weird like its dieing noise and when you trun the key it clicks from the passenger side fo the truck but nothing happens it doesnt turn over or anything what is going on!!!!??????
there is no corrosion now its not clicking in the truck its near the fuse box under the hood and when i turn the key to start it i hear a humming sound coming from under the driver side of the truck
it was my battery i have a 1997 ford explore in the backyard with the 5.0L and i pulled that battery and yea it runs smooth i took my old battery to advance and they said it wouldnt hold a charge it had about 10.5 volts and that was it and i have one more question when i put the 5.0L battery in my yota the battery gauge is higher almost touching the 18 mark is that a good thing or bad?
you need to check the charging voltage with an accurate voltmeter to verify it is not any more than around 14.2-14.7 with the engine running. anything higher than that is going to overcharge the battery, boil off the electrolyte and damage the battery and can damage other parts of the electrical system of the truck.
for the record, my 91 settles at about 14.5 within a few minutes of starting, and my 88 settles about about 14.3
smilen724
13
11-08-2015 04:11 PM
