Basic manual windows
How hard is it to make my bare doors have manual windows? Just picked up a 86 4runner that has doors, glass (with the small windows) and that's all. Btw I did a search and shuffled thru first 4 pages. Thanks y'all!
Staff
Depending on if you have the wing glass or no wing glass. The rail that supports the window is different lenghts. All of the mounting holes are in there. You will need the plastic tabs that go into the doors to make the screws hold them. Not a bad job to do in my opinion.
Staff
I am not sure if the electric window channel on the bottom of the window is different or not. The glass should slide out of it if it is different and you can make it work.
Post where you are located so you can find other members nearby with manual windows on similar year-model.
Compare mounting holes and regulator parts, etc on your door with theirs.
Decide if possible to convert.
Buy them pizza and beer.
Cleveland tn...just outside of chattanooga
jasonty
41
12-23-2018 01:00 PM
