| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
balljoint spacers and shocks
#2 (permalink) |
Here is a suggestion.
Put in the spacers, attach your old shocks. Jack the truck up until the arms can go to full droop. Once that is done, look to see if you're upper A-arm is hitting the bumpstop. If it is, then you don't need new shocks. If not, then you need longer shocks. However, as long as you don't go immedately out and take it offroad where you'll be lifting tires off the ground, you'll be fine driving normally on the road with the too short shcoks. You can then buy longer travel shocks at your convinence.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#3 (permalink) |
That's what I needed to hear - that was my original plan, but I was concerned about breaking a shock or shock mount. This truck is my daily driver and I'll be doing the install at a friend's garage half an hour away (read: I'm driving home after the install whether it's working or not).
#4 (permalink) |
yeah, you won't damage the shocks at all as long as you don't go to full droop should they happen to be too short. If they are, you are just fine driving on road until you can get a longer shock.
__________________
#5 (permalink) |
You can go to autozone and pick up a set of shock tab extenders. I used these extenders when I was working with my Rancho arms. I ended up cutting some length off the shock stud and then putting the extender on. All you need to do is unload your t-bar, flex the arms up and down and see how much length you need to add while still able to fully compress. Then cut and add the extenders as needed.
__________________
1986 Truck - Monster IFS 1997 FZJ80 - Locked, Lifted, Ready Range Rover Recovery Vehicle |
#6 (permalink) |
i just installed shocks on my truck in the front finally. they are rancho 5000s and it does make a pretty decent difference compared to the stock ones. but if you drive on the road alot then they are not needed right away. buying rear shocks is a must in my mind though.
__________________
1990 Toyota 4Runner, 154,000. 5 speed v6 Downey HD coils | 32x11.50s BFG all terrains | 15x8 Eagle Rims | Aisin Manual Hubs | BJ Spacers | Coil Spring Spacers | Rancho 5000s Front | Pro Comp ES3000 Rear | MagnaFlow Cat Back One cool sticker that reads "Toyota 4Runner 3.Slow" 12" Coustic Sub|MTX AMP |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Help Balljoint spacers | Bejiita | 86-95 Trucks & 4Runners | 30 | 07-19-2007 11:49 AM |
| Balljoint spacers... | Hofmeister | Offroad Tech | 25 | 02-22-2007 11:03 PM |
| 2wd balljoint spacers | Robert m | 86-95 Trucks & 4Runners | 0 | 11-14-2006 08:55 AM |
| Balljoint spacers | sc87yota | Offroad Tech | 2 | 03-25-2006 06:55 AM |
| Random though on balljoint spacers | Praufet | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-26-2004 11:53 PM |
