Ball joint weirdness - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-05-2007, 12:10 PM   #1 (permalink)
Squiddy's Avatar
So, I went to the shop (normally trustworthy, but starting to suspect not so great at complex stuff) and asked to do alignment. They said they couldn't as lower ball joints were bad. These had in fact been replaced by Toyota about 3000 miles previously (during steering rod recall), so I took it back to Toyota dealership, who looked it all over and said (at pain of owing me a lot of dough if anything goes wrong) all looked fine, and were stumped. Looks fine to me too. Any ideas? This all occurred after putting in new shocks, sway bars, bushings, tires, etc.
Squiddy is offline
Old 02-05-2007, 12:45 PM   #2 (permalink)
gonzo's Avatar
Send a message via Yahoo to gonzo
Why not just have the dealer do it?
I wouldn't trust that shop if they can't tell if a balljoint or anything else is good or bad. LOL
__________________
88 Toyota pu 4x4 22re 5spd. 4:88's, 2-1/2" exhaust from cat back, 3" BL. 33x12.5 thornbirds for play, 35 conti-trac for everyday. 10K winch. Pioneer with 4" kenwoods in front, 6-1/2 MTX's in rear on a 600W amp and 12" sub on a kenwood 120W amp. 600w power inverter.
91 Toyota pu 4.3 Vortec 5spd.
gonzo is offline
Old 02-05-2007, 02:51 PM   #3 (permalink)
JEBSR5's Avatar
Quote:
I'm with Gonzo, just have the dealer align and you should be good to go, unless we missed something. Is it pulling or drifting that you forgot to tell us.
__________________
90 4R SR5 4WD 5SPD
3VZE
211K miles
'69 Ford Mustang Mach I
'82 Suzuki GS1100E
'68 Chevelle SS396
'99 1/2 Pathfinder LE
JEBSR5 is offline
Old 02-05-2007, 03:03 PM   #4 (permalink)
MudHippy's Avatar
Loose wheel bearings, caused by the spindle lock-nut backing off, will represent as a bad lower ball joint. If you have tools, it's not hard to check if that's the case. However, you'll need a spindle nut socket to tighten it back down. Torques are all specific, don't mess around there, either.
MudHippy is offline
Old 02-06-2007, 07:29 AM   #5 (permalink)
Squiddy's Avatar
Well, the dealer was the one that gave it the re-once-over and swears all is fine with the ball joints, and aligned. What I was interested in is really represented by the last post - i.e. "other stuff" that might be presenting the same way.
Squiddy is offline
Old 02-06-2007, 08:29 AM   #6 (permalink)
I was told the same thing when I went for an inspection last year, but upon closer inspection it was indeed determined to be the bearing torque.
You can check the balljoints yourself by jacking the front end up, and holding the wheel at 12, and 6, and attempting to wiggle it. If it wiggles theres an issue.
MMA_Alex is offline
Old 02-07-2007, 07:31 AM   #7 (permalink)
Squiddy's Avatar
Well, once the thermometer climbs above frozen-solid will check the spindle thingies. I had done the wheel wobble before and was not impressed...
Squiddy is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ball joint spacer TheGhost Newbie Tech Section 4 07-15-2007 09:03 AM
New here and need help with upper ball joint Stal 95.5-2004 Tacomas & 96-2002 4Runners 7 07-15-2006 08:12 AM
lower ball joint Thrillbilly 95.5-2004 Tacomas & 96-2002 4Runners 2 06-27-2006 06:40 PM
Ball joint spacers??? 4unner4life 95.5-2004 Tacomas & 96-2002 4Runners 1 03-02-2005 02:11 PM
Anyone have ball joint problems ?? carose725 95.5-2004 Tacomas & 96-2002 4Runners 0 07-27-2004 07:42 PM
2009 InternetBrands, Inc.
