Ball joint spacer install help
Old 08-14-2013, 06:49 AM
Corey Barlow's Avatar
92 4runner, I bought ball joint spacers and lc coils. I was wondering if it was possible to just bend the extra metal on the control arm instead of grinding it? I don't mind grinding it but I'm at school and live in an apartment and if you make any noise they come yelling at you to stop so I'm looking at different options. If I have to I can wait till I go home to use my dads shop but wanted to get it done now. Thanks for any help
Old 08-14-2013, 08:26 AM
Yotard's Avatar
From my experience no you have to grind it or cut it away, it is fairly thick. Even if you could bend it, it would probably cause a fracture to start so I wouldn't do it anyway.
Old 08-14-2013, 08:31 AM
How hard is it to remove the control arm? Undo torsion bar and take out the 3 bolts ontop?
09-04-2015 09:27 AM
krimsonone
07-29-2015 11:53 AM
coffey50
07-28-2015 10:55 AM
msane99
07-27-2015 06:14 PM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Ball joint spacer install help
