ball joint spacer install - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-13-2006, 05:38 PM   #1 (permalink)
Hi everyone, Im new to this forum and have been looking through it day and night. I think its a great forum. Anyway, I have noticed that many people in here seem to take a liking to the bj spacers to get a little lift in the front. I am highly interested in doing this to my 94 4x4 pickup. I don't have any tools to cut the uca and called my 4wheel shop here to see if they could install it for me. They had no idea what it was, along with every other suspension shop, and said they wouldn't do it. I read on another thread about shaving the spacer to fit, instead of cutting the uca. It got no responses and I was wondering if that would be possible to have a shop grind down the spacer, so I could install it myself. Thanks for the help. Sorry for the long post.
wailukutoy is offline
Old 03-13-2006, 05:55 PM   #2 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
You can rent a grinder cheap. No need to buy if you won't need it.
I remember reading about that a while back also (shaving the spacer), but don't remember who.
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 03-13-2006, 05:58 PM   #3 (permalink)
I would definitely rather cut the spacer, than the uca. Would that be ok?
Old 03-13-2006, 06:52 PM   #4 (permalink)
BeaterToyota's Avatar
I ground out the UCA a bit to make mine work. When you do this, you're not really getting rid of anything structural, you're just enlarging the opeing that's already there. I would go that route rather than shaving the spacer.
You should be able to rent a grinder pretty cheap from an equipment rental place, but why not buy a cheap one and then you have it for next time you need it? You will need it some other time, and you'll be glad you have it sitting around.
BeaterToyota is offline
Old 03-13-2006, 08:10 PM   #5 (permalink)
celica's Avatar
I looked at shaving the spacer when I did mine but you would end up taking too much off & ruining the integrety of it. I ground down my UCA instead. You can get a grinder for $20. Well worth the investment. I use mine all the time to cut off ald rusy bolts, etc.
__________________
Matt
2003 4-Runner Limited - Couldn't stay away from the runner
2003 Sequoia Limited
1989 Supra Turbo
1992 4r, 5spd V6 Sold
celica is offline
Old 03-14-2006, 08:37 AM   #6 (permalink)
Thanks for the input. Is it that easy to do it yourself? I have little mechanical skills and tools. It seems pretty straight forward, but I am afraid of messing anything up like the shafts, and having problems with binding like some other guy on the forum did. How hard is it really, for someone with little experience and tools? Thanks everyone, appreciate the help.
Old 03-14-2006, 10:11 AM   #7 (permalink)
celica's Avatar
Don't worry about the binding - that was the only case I have ever heard of. It is fairly easy to do. follow the instructions & just be carful not to pull your cv shaft apart. other than that it was pretty easy. You will need an alighnment after - it will look like Daffy Duck & be really squirly on the road until you get it aligned
__________________
Matt
1989 Supra Turbo
celica is offline
Old 03-14-2006, 11:25 AM   #8 (permalink)
NRM
NRM's Avatar
Send a message via AIM to NRM
i had never used a grinder for anything before and when i installed my bj spacers i rented one and easily ground down the UCA. all you have to do is put the spacer where its supposed to go and see how much you have to take off. the whole job took a few hours, not a big deal. and everyone on the board is always here to help if you get stuck halfway through the job!!
__________________
Nate
1995 4Runner sr5 V6 4WD auto: 32" BFG A/T's on black rock crawlers, 4.88's, jardine exhaust, OME 900 coils, BJ spacers, procomp shocks and steering stabilizer, aisin manual hubs.
My 4Runner
NRM is offline
Old 03-14-2006, 07:15 PM   #9 (permalink)
slosurfer's Avatar
The grinding is the easy part, finding out how to raise the uca high enough was the hard part for me. I would definately buy a grinder rather than rent one, you will be surprised how much you use it. One tip if you get a 4.5 in. grinder, go ahead and use a 4 in. cutting wheel. I have a 4.5 in. grinder and used the 4.5 in. wheel and the first side was real tight getting it in there. The next side was easier because the wheel had worn down a little bit.
I am the one that had the binding problem. I am still not sure what the problem was, but once I had it aligned it fixed the problem. Something was way off on my driverside and the whole wheel was closer to the diff. than it was supposed to be, causing the angle to be greater than it should have been. It wasn't drooping any further than the pass. side, just the angle was greater for some reason. Anyways, I am completely happy with them and have had them offroad about every weekend since. Also, having all the help from everyone here was awesome. I also know a little more about my front end, which is always helpful.
__________________
Chris
7th Annual Pismo Jamboree: Sept. 25-27, 2009
'93 4runner SR5 3.0 Auto 4WD
'07 Tacoma Dcab 4x4 TRD offroad
'89 F250 4x4 w/utility bed
M416 1/4 ton military trailer
"Some people spend an entire lifetime wondering if they made a difference. The Marines don't have that problem."
Ronald Reagan
Semper Fi
SLO 4wheelers
slosurfer is offline
Old 03-14-2006, 08:46 PM   #10 (permalink)
Thanks everyone this is really helpful to me and I am grateful for the input. I went to my auto shop today and looked at buying a tool to do the trimming. The install suggests an angle grinder or cut off wheel to do this. What would be better, or is there no advantage of one over the other. The angle ginder was $20 and the cutting wheel was $40. I don't mind spending the extra money if the cutting wheel would be that much more worth it, or is it not? Thanks again.
Old 03-14-2006, 08:49 PM   #11 (permalink)
Staff
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
i picked up a $30 Ryobi 4" angle grinder when i installed mine. i have used it more times then i thought i would ever would when i bought it.. well worht the 30 bucks i spent.
__________________
94 4runenr: all the good stuff.......
89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs.
81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s
pacific-crawlers.com
For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :)
Tofer is offline
Old 03-14-2006, 09:10 PM   #12 (permalink)
With such a great solution to cranking T bars for a little lift, why are the spacers not a common thing? THe shops here in HI had no idea what they were, is it just this state or are they not common at all. One more quest. Would installing the spacers to obtain a 15" rim/fender limit cause the same increased angles on all suspension parts, such as the cv joints, as cranking the T bars to a 15" limit, or would does it not work out that way.
Old 03-15-2006, 10:07 AM   #13 (permalink)
tc
tc's Avatar
Quote:
Yep. Inside of CV is still attached to the frame and outside of the CV is still attached to the wheel.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 03-15-2006, 02:43 PM   #14 (permalink)
They were developed by some guys on 4x4Wire (and YotaTech) in the summer of '03. Basically not many people outside of these two message boards are all that familiar with them. Click here for the original, and ultimate, ball joint spacer thread from 4x4Wire.
Old 03-16-2006, 03:24 AM   #15 (permalink)
Banned for stupidity
V_Runner's Avatar
anybody got pics. of where the BJ spacers go???
V_Runner is offline
Old 03-16-2006, 10:18 AM   #16 (permalink)
PAhydrohead's Avatar
Quote:
Originally Posted by slosurfer
The grinding is the easy part, finding out how to raise the uca high enough was the hard part for me....
I'll second that!! I used my bottle jack but it took a little while to figure out where to shoe horn it in there.
A grinding wheel shouldn't be $40! That's more like a diamond tipped masonry blade. Check out this link. This is similar to what you want to buy http://www.grainger.com/Grainger/wwg...691624&ccitem=
PAhydrohead is offline
Old 03-16-2006, 09:59 PM   #17 (permalink)
BLKNBLU's Avatar
Quote:
Here ya go
Pics start at post #17
http://yotatech.com/showthread.php?t=58081
and here's a link to another set of pics
http://sonoransteel.com/san_diego_of...olutions_.html
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB
My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/
BLKNBLU is offline
Old 03-18-2006, 09:36 PM   #18 (permalink)
did you go to maui offroad for the work. There's a couple better guys down there that do thier own work. And know what they are doing.
gsi23 is offline
Old 03-19-2006, 12:09 AM   #19 (permalink)
I actually called maui off road, and 4wheel parts on Oahu. Who would you recommend?
Old 06-13-2009, 05:55 PM   #20 (permalink)
Teuf's Avatar
Send a message via AIM to Teuf
i may get a set of 1" spacers, and then back of the torsion bar for 1 inch less to retain my current height, i have a 3 inch rancho lift n heavy duty tb
Teuf is offline
Old 06-13-2009, 06:59 PM   #21 (permalink)
4banginRunner's Avatar
Quote:
whats with all the 3yo thread bumps today?
__________________
87 Toyota 4Runner
22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time...
79 Toyota Longbed 4x4
Frame-off Resto time.
04 GMC Sierra 1500
the DD
4banginRunner is offline
Old 06-13-2009, 08:14 PM   #22 (permalink)
scuba's Avatar
Quote:
Dude thats honestly been happening almost every day since 1/01/09..
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 06-13-2009, 08:29 PM   #23 (permalink)
89silverpu's Avatar
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
At least the newbs are searching
__________________
'89 Beater Jeep Eater in progress
4.88's, TRD e-locker, Dual Cases, 33's, Armored,
Tread Lightly
Mixchallenge.info
89silverpu is offline
Old 06-13-2009, 08:37 PM   #24 (permalink)
Junkers88's Avatar
Quote:
Christ it's about time.
I for one never really get tired of Scuba yelling "SEARCH!!!!" but I'll bet the new guys do.
__________________
RB4R Life Member.
1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header.
Junkers88 is offline
Old 06-13-2009, 08:37 PM   #25 (permalink)
This is true!...just like 14 bumped dead threads in one day though... haha
We were all newbs once...SEARCH FTW!
__________________
87 Toyota 4Runner
04 GMC Sierra 1500
the DD
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
ball joint spacer TheGhost Newbie Tech Section 4 07-15-2007 09:03 AM
ball joint spacer question tedfrk Newbie Tech Section 1 06-29-2007 08:46 PM
Ball Joint spacer question. mtrdrms 86-95 Trucks & 4Runners 9 01-31-2007 05:20 PM
Another cruiser coil/ball joint spacer install zambo 86-95 Trucks & 4Runners 4 07-11-2006 03:17 PM
Help! Ball joint spacer install SWORDFISH92 Offroad Tech 7 08-08-2004 10:00 AM
2009 InternetBrands, Inc.
