Ball Joint question!
Old 06-18-2012, 12:42 PM
4runninmuds's Avatar
Hey guys, kael here. I am replacing my ball joints this afternoon and I cannot for the life of me find out if the ball joints need to be pressed in on a 94 4runner 4WD. I've got the pickle fork to get them out but the write up I found doesn't specify how the new ones go in. Which could've meant they just go in and are torqued down with the castle nut, but I dont know. Any help, or recommendations would be much appreciated.
Cheers
Kael Klein
Old 06-18-2012, 12:51 PM
snobdds's Avatar
They don't need to be pressed in. Just troque the 4 bolts to spec and your done.
Old 06-18-2012, 12:55 PM
yoder519's Avatar
yep no pressing needed. There a PITA to get out though. A pitman arm puller works great for the lowers depending on how long they've been in for.
Thanks for the reply!
Old 06-18-2012, 01:02 PM
Only replacing the upper ball joints, the reason being, during my attempted spacer install I sheared one of the bolts off(SO rusty). I'll get some fresh units in there and be good for a long time! One more question if you guys don't mind: the ball joints I bought(OE I believe) have studs in them. How might I go about removing these to make room for the long spacer bolts to go in? Or is my noob "driveway mechanic-ness" showing through here haha.
Thanks for the help fellas, yotatech is the bees knees
Old 06-18-2012, 02:18 PM
highonpottery's Avatar
hammer the studs out - just be careful not to hit the boot and you'll be ok with a regular hammer or whatever you've got. watch it with the 4 mounting bolts to attach BJ+spacer to a-arm - since they're most likely not grade 8 you gotta watch for stripping the threads and not over torque them. steering knuckle gets torqued to the BJs like normal. No special tools needed for this job.
Old 06-18-2012, 02:26 PM
Thanks! Exactly what I wanted to hear
09-04-2015 09:27 AM
gillesdetrail
08-03-2015 04:43 PM
krimsonone
07-29-2015 11:53 AM
coffey50
07-28-2015 10:55 AM
ksmudrunner99
07-21-2015 05:33 AM
Quick Reply: Ball Joint question!
