Ball Joint Help!
Ball Joint Help!
Hey guys,
in the middle of doing upper and lower ball joints on my '90 4x4. I've managed to get the driver's side done with a pickle fork. My question is do you have to press the ball joints back in or is tightening the nut sufficient? I don't really have any way to press them in...if I tighten everything up as much as possible can it be done when I get an alignment?
Thanks!!!
Thanks!!!
For studs found on the steering, I've always put anti-seize in the hole, then tightened the nut until the slots on the nut line up (in a vertical sense) with the hole in the stud. Then you put your cotter pin in and call it quits. No press, no torque wrench.
Also, I find pickle forks really suck on their own. I use a pitman arm puller in conjunction with the fork. Crank the puller until its tough to turn anymore, then smack it with the fork. Usually pops right out.
$30 pitman arm puller:
spin around 3 times, jump in the air and click your heels together then grease the joint...
... and check it periodically. If you put any grease / anti-sieze lube / etc. in where the joint mates with the arm, over time the grease or lube will migrate out leaving a void that will only turn in to free-play.
Well, spacers, shocks and four new balljoints are in. The pickle fork worked for three but the passenger side lower had to be grinded in half so I could get get the press I'd rented to work. Wahoo. DONE!
kawazx636
10-06-2021 03:03 PM
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
