bad vibration
Old 10-16-2009, 08:07 PM
scottydogg's Avatar
bad vibration
I just replaced my clutch braket, slave cylinder and clutch master cylinder. Everything was fine until this morning and now when I put in reverse or out of gear and let off the clutch I get a BAD VIBRATION. iF YOU STEP ON THE CLUTCH IT GOES AWAY OR THE BRAKE. I dont know if my clutch is bad now or what is going on, but I am almost afraid to drive it cause of this problem. Could it be my throw out bearing?
Old 10-16-2009, 08:09 PM
camo31_10.50's Avatar
well i thought it might be the flywheel not being tightened allll the way..but then you said it quits if you step on the brake...so im lost..LOL
Old 10-16-2009, 08:24 PM
crawlerjunkie's Avatar
we just the motor in buddies 4r for the same exact reason. He said he checked every bit of the transmission, but sure enough after the motor was out we found a half eaten flywheel bolt.
Old 10-17-2009, 06:14 AM
yoterr's Avatar
had the same prob turns out it was a loose pinon nut....so yeah you got some checkin out to do lmao, while ur down there check out your u joints
Old 10-18-2009, 04:41 PM
scottydogg's Avatar
vibration
This has really got me confused. Put it in neutral and start it up and it vibrates so bad, that it shakes the whole thing. Rev it up and it stops, push on the clutch it stops, step on the brake, it stops. No vibration while driveing or at a stop light unless you take it out of gear and let off the clutch and people next to you look at you wandering if its going to blow up.
Blamalam
08-16-2015 12:29 PM
tinigunner11
08-14-2015 01:19 PM
lectric80
08-11-2015 12:02 AM
Quick Reply: bad vibration
