Bad Oil Pump
Old 08-02-2009, 07:34 PM
myyota's Avatar
Bad Oil Pump
The oil pump on my truck died and it chewed up the the gear that slides over the crank shaft that drives the oil pump, were can it get this gear, and my next question is, would using a used oil pump be ok or should i buy a new oil pump ?.
Old 08-02-2009, 07:50 PM
totally a bro
Staff
vital22re's Avatar
if you buy a new pump it should come with the gears
Old 08-02-2009, 08:07 PM
myyota's Avatar
The gear that im talking about slides over the crank shaft, and then the oil pump with its gears slides over that gear and drives the oil pump.
Old 08-02-2009, 08:08 PM
totally a bro
Staff
vital22re's Avatar
or right.. gotcha... maybe find one of those used... otherwise.. dealer...
Old 08-02-2009, 08:15 PM
myyota's Avatar
Originally Posted by vital22re
or A.. gotcha... maybe find one of those used... otherwise.. dealer...
I hope i can find a used one somewere, im sure the dealer would be very expensive, damn, if its not one thing its onother.
Old 08-02-2009, 08:47 PM
Jay351's Avatar
Find somebody parting out a truck. You can get a bad 22re (if you can find one) for cheap.. Like A few hundy. Then you got tons of spare parts, or you can sell parts..
Or just buy the oil pump drive splined gear from a bad motor.
Old 08-03-2009, 04:57 PM
iamsuperbleeder's Avatar
http://www.toyotacatalog.net/M1WebGe...B-215139B77B41
Old 08-03-2009, 05:07 PM
Junkers88's Avatar
I'd say pull a junkyard oil pump and check the tolerances. If it checks out then buy it and install it, if not then pull another one and do the same until you find one that checks out. Be sure and buy a gasket set.
Oil pumps off of our engines out here go for 7.50$ a shot. You can do a lot of looking for that amount of money and the time it takes to pull one.
Old 08-03-2009, 05:22 PM
myyota's Avatar
Originally Posted by iamsuperbleeder
Thanks superbleeder, i just placed an order.
Old 08-03-2009, 06:35 PM
myyota's Avatar
Ok, everything is ordered, new spline gear and oil pump, about 150.00 for everything, and it should be here by this friday.
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
jakebarrett
07-10-2015 07:15 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Bad Oil Pump
