Bad Idle, TPS Questions???
whenever i first start up my truck it idles fine , but whenever it warms up it wont idle worth crap.. you can be driving push in the clutch put it in neutral and the rpm bounces between 0 and 200.. the idle adjustment is almost all of the way out and when i do adjust it, it dosent seem to do anything..
i took the throttle body off and cleaned it out and when i took the tps off i noticed that the tps had slots, like it could be adjusted.. <<could my tps be out of adjustment? or do i need a new tps??
any help on this subject is greatly appreciated!
You definitely have to adjust the TPS now after taking it off. Also turn that idle screw down. This link will help:http://personal.utulsa.edu/~nathan-b...fsm/index.html
