bad grinding sound
bad grinding sound
i just put in a 4 inch rear lift and am awaiting my bj spacers, but get a little vibration on the drive shaft right now, i expected this and got the adjustable upper control arms to help it, but I get this weird grinding around 50km/h which is about 30 mph. kinda sounds right under my seat and I'm freaked out my driveshaft wobble is wrecking something expensive... any ideas?
Put the rear on jackstands, truck in neutral, chock the front wheels, get under there and turn the driveline, see if you can feel the ujoints binding, or maybe you have a long bed with the carrier bearing... Which hates lifts anyways
start the rig up and put it in gear and got through the gears and speedometer and listen and look for binding and noises.. you might get more noises than normal with no load on the rear but you should atleast be able to get under the truck and hear your specific noise or grinding and pinpoint it.
be careful tho
be careful tho
its a 4wd 4runner.... 94 22re. I cant quite get the sound pinned down. its only really when I go from coasting in 2nd or 3rd to speeding up for about 5 seconds. i just lubed all the joints except the double cardans cause I gotta get a tube of moly. although i may try adjustng the upper arms so they are shorter see if that helps... i dont wanna rip off the upper arm mounts like so many guys have... lol
keep the ideas coming... i"ll let ya know if i find it i mean it could be a loose piece of metal that now dances at certain vibrations when I drive who knows
well its kinda a mesh of parts.... procomp springs (4") rancho 9000 adjustables, used and I hate them. some adjustable upper control arms, made my own panhard drop got a buddy to weld it up for me, and a nice brake braided brake line.
i may have found the sound... i just noticed the hanger to the cat was broken and hanging loose... so maybe it was banging around down there... will find out when I go to the store...
Shaun Crystal Gomban
07-30-2015 10:13 PM
