Bad fuel sending unit blowing efi fuse?
Old 01-06-2012, 03:58 PM
noclinkers's Avatar
Working on a 90 runner 3vz. Blew the efi fuse, so I checked the 02,maf,ecm, and they are all good.
When this first happened I was driving when the low fuel light came on, but the tank was full. Not long after that the fuse blew and after that the guage reads properly with just the key on , but when I start the rig it grounds out and goes to E.
I haven't pulled the tank yet, but I was wondering if there was any relation between the sending unit and the efi fuse, cause I would not think so?
Old 01-06-2012, 04:05 PM
alltracman78's Avatar
Off the top of my head, the sending unit doesn't use the EFI fuse.
Double check the wiring diagrams to make sure.
To check for a short you can jump a light bulb instead of your fuse. This will allow the circuit to stay active so you can check it.
Old 01-06-2012, 04:52 PM
noclinkers's Avatar
yeah you're right it doesn't, but I was thinking maybe the fuel pump circuit and the sending unit cercuit could be rubbing on each other. Guess I won't know until I pull the tank.
Old 01-06-2012, 04:58 PM
Just disconnect the connector and see if it still blows the fuse. If it does it's not in your tank.
If not, it's probably in the tank.
Old 01-06-2012, 05:13 PM
shaeff's Avatar
My guess is that you've got an o2 sensor shorting out.
Old 01-06-2012, 05:55 PM
noclinkers's Avatar
The sensor itself?, cause I followed wires and they look good.
Old 01-06-2012, 06:03 PM
abecedarian's Avatar
All the wires? Both O2 sensors?
Old 01-06-2012, 07:39 PM
noclinkers's Avatar
"Both"? There is only one that I know of?
Old 01-06-2012, 07:52 PM
93YotaGuy's Avatar
It depends on what type of vehicle emissions you have. For example a california pickup has two O2 sensors. One before the cat, and one after the cat.
Old 01-06-2012, 08:34 PM
noclinkers's Avatar
This model has one just before the cat.
Charecter1
11-06-2023 10:08 AM
MO transplant
04-23-2023 11:58 AM
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
dpridgeon3
07-09-2015 01:18 PM
Quick Reply: Bad fuel sending unit blowing efi fuse?
