backward headgasket? how do I know?
Some of you may remember my earlier threads about intermittent overheating.
https://www.yotatech.com/forums/f116...s-down-122042/
https://www.yotatech.com/forums/f116...-gurus-123343/
Since the shop that did my headgaskets wasn't solving the problem, I took it to another shop for their opinion. They are saying that the headgaskets were improperly installed, and that you can see a part of the headgasket sticking out (I'm going after work to check it out). Does this sound right? If they're not in properly, does a part of the gasket stick out?
all the holes (coolant passages, etc) should be free, and not have pieces of gasket hanging into them. I believe the issue was partially covering a coolant passage
yes you can reverse the head gasgets, i have and that overheated. the thing is though that you will always overheat when you have the headgasgets reversed. the only way i was able to keep it from overheating was to take out my thermostat, but then it took way to long to get the engine to operating temperature.
TheBFA
02-15-2020 06:55 AM
_Nicco_
09-21-2015 03:06 PM
defrag4
07-31-2015 10:50 AM
