Axle Oil Seal
Old 12-09-2010, 07:24 PM
peow130's Avatar
Axle Oil Seal
Okay so i have a dilemna..
Picked up my diff (thanks 82blueyota)..
Started tearing everything apart.. Going well, until i pull both axle shafts and notice that i didn't quite get all the muddy grit out of my drivers said axle shaft, and that the little rubber circle piece has seperated it'self from the metal ring.
Now, the rubber it'self isn't torn, or broken, or anything like that.
It just sperated from the metal seal on the end of the axle.
Is it supposed to be able to seperate from this? Or.. Is it toast and do i just need to go buy a new one?
I did look through the FSM, and it just shows they use a slide hammer to pop it out. And a flat ring to pop it back in...
Old 12-09-2010, 09:32 PM
peow130's Avatar
Well for anyone searching for this, the answer was no.
Old 12-10-2010, 04:30 AM
waskillywabbit's Avatar
Replace that seal anytime you pull the axles. Cheap insurance.
:wabbit2:
jasonty
41
12-23-2018 01:00 PM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
jakebarrett
07-10-2015 07:15 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Axle Oil Seal
