Auxiliary fuel tank for 1st Gen 4runner
Old 07-13-2011, 10:04 AM
edeslaur's Avatar
I live in the southwest, where we often go long distances offroad.
Since my range is so poor on my 4Runner (17mpg @ 15 gallons = 255), I need to add a spare gas tank. 17 is a bit optimistic since it's quite hilly out here and gas has ethanol in it (at a cost of 10% mpg over non-ethanol), and offroad uses more, not less.
Any vendor suggestions or any used ones available?
Any issues to report with yours (install or long term ownership)?
Old 07-13-2011, 02:18 PM
myyota's Avatar
I saw some pictures (not sure if it was here or not) were someone took a gas tank from a chevy blazer and mounted it between the frame rails were the spare tire mounts and plumbed it into the stock fuel lines. I remember them saying they could go over 500 miles between fill ups.
Old 07-13-2011, 07:22 PM
91diesel's Avatar
I'm looking into this but plan on using an early 90's ford rear fuel tank. You can get them new at a very reasonable price and I plan on using the ford fuel pump to transfer fuel to the stock tank. These tanks are 19 gallons and much smaller than the chevy blazer tanks (34 gals but hang real low). If you do a google search you can see some writeups on it.
Old 07-13-2011, 09:53 PM
myyota's Avatar
Im not talking about a full size chevy blazer gas tank, im talking about using a gas tank from an S10 blazer.
Old 07-13-2011, 10:16 PM
Fossilized
Staff
dropzone's Avatar
is your friend:
http://www.nwmp.com/viewOptions.asp
Old 07-14-2011, 03:36 AM
Utah4Runner86's Avatar
This help any?
Old 07-14-2011, 05:14 AM
corax's Avatar
Ford tank if you don't mind moving your spare tire, or NWMP tank if you want to keep your spare where it is. Here's my NWMP tank install if you're interested: https://www.yotatech.com/forums/f123...ansfer-218625/
Old 07-15-2011, 09:24 AM
edeslaur's Avatar
Nice links! I spoke with Wesley at NWMP, the location of the fuel filler neck may pose a problem for my setup at full articulation stuff on that side.
Care of Corax's super-awesome-excellent thread, I was able to see what Wesley meant:
I'll have to see what it takes to Y into the regular filler. I'll crawl under this weekend.
The spare clearance with the tank is another concern. While departure is "good" to the bumper, my bumper drags on rocks all the time.
I need a bumper-mounted spare anyways.
Old 07-15-2011, 05:57 PM
corax's Avatar
I was only slightly annoyed last winter (in southwest Colorado) when the aux tank filler kept getting iced up - it was nice having an extra 85 lbs over the rear axle for traction. So I've had my eye recently on trying to get my hands on an extra fuel door/filler neck pocket so I can take the filler neck into the passenger rear "storage" area and up to the area just above and behind the wheel well. That would pretty much solve that issue and shouldn't be too difficult to accomplish.
Old 07-18-2011, 08:35 AM
edeslaur's Avatar
I'd be concerned running chains with that setup...
Old 08-10-2011, 08:51 AM
edeslaur's Avatar
My used tank has arrived!
I need to finish the lift and locker install, then the tank is up next.
This thread has a great idea on how to plumb a truck which is going to be dragged across rocks and such.
Gotta love the posts!
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
westbound
06-07-2002 03:30 PM
Quick Reply: Auxiliary fuel tank for 1st Gen 4runner
