Aux light connect to positive battery terminal/cable
Old 05-06-2007, 07:06 PM
bad_brains's Avatar
For folks with Aux lights such as the Hella 500 kit:
How did you connect the red lead from the relay to the positive battery terminal/cable?
My inclination was to fray the wire end and wedge it to the terminal post with the cable clamp. Better methods?
Old 05-06-2007, 07:19 PM
waskillywabbit's Avatar
You can look on Hella's website and get installation instructions...and there are numerous write-ups online. Try
Old 05-06-2007, 07:43 PM
Elton's Avatar
use a inline fuse and run it to any 12v source
dibble9012's Avatar
Use a ring terminal on the wire, crimp AND solder it for a good strong connection.
Once you have properly soldered and crimped the terminal onto the wire, just unbolt the neg and pos battery wires, and there should be a nut that you can take off on the positive side, where the stock fuse box connects to the clamp.
Remember to put an inline fuse or circuit breaker AS CLOSE TO THE BATTERY AS POSSIBLE. This is very important because it will prevent your truck from burning up if you get a short somewhere.
Old 05-06-2007, 07:47 PM
OSU4Runner's Avatar
I installed an aux fuse box under the hood for all my accessories, and then ran the hellas off of that! Really cleans up the wiring mess under the hood
Old 05-06-2007, 07:48 PM
dibble9012's Avatar
yup I did the same thing, both a 6 slot fuse box and a 4 slot relay box, both weather resistant. It really does clean everything up.
v_man
07-23-2015 04:01 PM
rushw
07-18-2015 01:46 PM
Odin
07-15-2015 09:28 PM
Huntingtruckcletus
07-08-2015 05:26 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Aux light connect to positive battery terminal/cable
