auto trans wont shift
Old 06-07-2010, 02:20 PM
busted-pickup's Avatar
hi i have a 1990 yota pickup 4x4 automatic it quit shifting the other day i backed up an put the selector in drive and the truck wouldnt move it had been shifting rough so i thought the transmission was cooked got another transmission and installed it with new torq converter and still the same thing i can put the selector in any gear and it wont move new saftey neutral switch also my question is is there a transmission computer on the truck if so where or is it one with the ecu any help on this will be greatly appreciated
Old 06-09-2010, 08:03 AM
bump bump
Old 06-09-2010, 05:26 PM
anyone?
Old 06-11-2010, 08:26 PM
annoyingrob's Avatar
Yes there's a computer just in front of the shifter underneath the radio. Un-plug it, and it will force the transmission to run manually. 1 shifts 1, 2 shifts 3, and D shifts OD. That will allow you to narrow it down to mechanical or electrical.
Old 06-13-2010, 12:42 PM
yotarover's Avatar
the other day mine wouldn't come out of park unless i used the unlock button to shift into gear it was dark couldn't see . next mourning i took the cover off and cut away all the small filmy slips. low and behold some of them had broken and lodged between the lil pin
fixed
Old 08-17-2010, 04:45 AM
mine doesnt have any computer in front of the shifter under the radio i took everything out any other ideas im at a lose does the ecu control the transmission on this model?
Old 08-25-2010, 01:41 PM
bumpity bump
Liadrin
04-25-2022 02:54 PM
Chumlee780
11-13-2015 03:18 PM
Liadrin
09-01-2015 06:44 AM
D.B.T. 87 4x4
07-20-2015 04:51 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: auto trans wont shift
