Auto Tranny - Lost OD - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-29-2007, 05:03 AM   #1 (permalink)
New to the forums...and, frankly, to pickup trucks. I've brought an abandoned '86 Pickup back to life but I'm still working out some issues.
22R engine, auto tranny. A few weeks back I replaced the AT fluid/filter and everything was fine until a few days ago. It does not shift up into OD anymore. L to 2 shift is smooth as silk, 2 to D shift is a little harder, and D to OD never happens no matter what I do. I've turned the OD switch on and off to no avail. Fluid level is ok, I've topped it off without overfilling but that didn't help. There is also a buzzing noise coming from somewhere that stops as I am adding trans fluid, then resumes.
Any ideas? Thanks.
mattsroush is offline
Old 01-29-2007, 07:30 AM   #2 (permalink)
Anyone?
I've searched the forums but didn't see anything quite like what I describe. I'm afraid I might lose D next because the 2 to D shift has gotten steadily worse over the past few days.
__________________
1986 2WD Pickup Longbed/X-Cab (RN70)
22R Engine, Auto Trans
305,000 miles
Old 01-29-2007, 07:49 AM   #3 (permalink)
mt_goat's Avatar
The ECU will keep the tranny from shifting into OD if it detects the coolant isn't hot. If you're lucky, it will just be something like that. Wishing you luck.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 01-29-2007, 07:57 AM   #4 (permalink)
mt_goat's Avatar
If you don't get lucky, I think I'd pull the valve body out and either send it to IPT for testing/inspection/cleaning OR try testing the shift solenoids myself. (not sure how to test them though) I've heard that things as small as lint from a rag can cause shift solenoids to malfunction.
Oh heres the link for IPT: http://www.importperformancetrans.com/downloads.shtml
If you do remove the VB make a little map of which bolts went where because there are 3 or 4 different lenghts and it does matter where they go.
__________________
~Dale~
mt_goat is offline
Old 01-29-2007, 08:14 AM   #5 (permalink)
mine did that once. I had the tranny flushed and it quit. Also,
thermostat may be bad.
brussell is offline
Old 01-29-2007, 09:27 AM   #6 (permalink)
I was planning on replacing the thermostat soon anyway (the engine takes quite awhile to warm up). I hope I get lucky too...
I'll give that a try.
__________________
305,000 miles
Old 01-29-2007, 03:06 PM   #7 (permalink)
4runnerx3's Avatar
Have you checked to see if the OD light will flash a code?
4runnerx3 is offline
Old 01-30-2007, 04:06 AM   #8 (permalink)
I've done a search and found many threads talking about "my OD flashed code XX", but I couldn't find anything telling me how to get the code to flash. Is there some method to make it flash, or does it flash automatically whenever it senses a problem?
It's certainly not flashing automatically...the light comes on when I turn the OD switch to OFF, and goes out when it's ON.
__________________
305,000 miles
Old 01-30-2007, 04:58 AM   #9 (permalink)
mt_goat's Avatar
Yeah you have to jumper a couple pins in the diagnostic plug under the hood. Sorry I can't remember for sure which pins it is.
__________________
~Dale~
mt_goat is offline
Old 01-30-2007, 05:12 AM   #10 (permalink)
I'll try the thermostat first. The less I know about the automatic tranny, the better I'm planning on doing a engine/tranny swap in about a year, so I just need to keep the thing running for now.
Oh, and about that buzzing noise...any ideas on that? Think it might be related? I see some folks have had an issue with some heat sheild vibration causing a similar noise, but the fact that the buzz stops as I add fluid makes me think it's a different problem (I assume there is some sort of AT fluid pump?)
__________________
305,000 miles
Old 01-30-2007, 06:05 AM   #11 (permalink)
mt_goat's Avatar
Quote:
How often are you having to add fluid? How long after you add fluid before the buzzing starts up again?
__________________
~Dale~
mt_goat is offline
Old 01-30-2007, 06:11 AM   #12 (permalink)
mt_goat's Avatar
Here's the "pulling the codes" info:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
__________________
~Dale~
mt_goat is offline
Old 01-30-2007, 06:28 AM   #13 (permalink)
ZUK
ZUK's Avatar
How's the color on the atf?....red...pink....tan...dark brown?
__________________
www.gearinstalls.com
2001 white Xtra-cab Taco 3.4L auto TRD
88 Runner/V6/auto/31"/5.29gears
ZUK was what my friends in 1990 "tagged' me with when I was building a brand new white 1990 Sami for a magazine cover. The name stuck and I haven't been able to shake it off....not even with antibiotics.
ZUK is offline
Old 01-30-2007, 09:16 AM   #14 (permalink)
Quote:
Quote:
I've only been adding a little fluid at a time thinking that when I replaced the fluid I didn't quite fill it up to capacity. I can't find any evidence of a leak.
The buzzing resumes literally seconds after the last of the fluid has run down the fill tube. It may just be coincidence that it stops as I'm adding fluid...it doens't make the noise Constantly, but fairly consistently.
(and thanks for the link....good stuff)
The color looks pretty good...reddish with just a slight brown tone. When I changed the fluid I didn't completely flush the system (quite a bit stays in the tq converter etc even when drained completely). I've probably driven 300 miles since the change, so it may be too early to tell if the color is way off.
__________________
305,000 miles
Old 01-30-2007, 09:25 AM   #15 (permalink)
gohawks's Avatar
vibration could be the dipstick vibrating on side of transmission pan.
__________________
SERENITY NOW!!
gohawks is offline
Old 01-30-2007, 09:54 AM   #16 (permalink)
mt_goat's Avatar
Quote:
Or maybe where the 2 sections of fill tube fit together. There is suppost to be an o-ring there maybe you lost it.
__________________
~Dale~
mt_goat is offline
Old 01-30-2007, 10:09 AM   #17 (permalink)
That sounds plausible. If there was ever an o-ring there I'm sure it disappeared sometime during the first Bush administration.
Either way sounds like you guys don't recognize the buzzing as any obvious mechanical issues.
__________________
305,000 miles
Old 01-30-2007, 10:21 AM   #18 (permalink)
gohawks's Avatar
Mine buzzes from time to time. Nothing that's ever really concerned me.
__________________
SERENITY NOW!!
gohawks is offline
Old 01-30-2007, 10:22 AM   #19 (permalink)
mt_goat's Avatar
Hard to guess without hearing it.
__________________
~Dale~
mt_goat is offline
Old 01-30-2007, 07:12 PM   #20 (permalink)
4runnerx3's Avatar
This is how to make the OD light flash a code. Look for a square plug behind the air filter/AFM box. Ground this plug. The FM shows a volt meter, just stick a piece of wire in it and ground the other end.
Then push in the OD button, switch the ignition to on, don't start. The OD ligth will flash a code. Here are the codes.
Old 02-10-2007, 07:32 AM   #21 (permalink)
Hey I just got a chance to look at this today...I don't see a sqare plug...should it be connected to anything else or should it be open? If so, there is only one open plug anywhere near that in my engine bay. I tried grounding that one as described above and nothing happened with the light. I'm a 22R (carb) if that makes a difference.
__________________
305,000 miles
Old 02-10-2007, 09:21 AM   #22 (permalink)
mt_goat's Avatar
This is from a 93 V6 but it should look something like this:
__________________
~Dale~
mt_goat is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
OD light flashing,tranny starting out in 3rd gear! nineball 86-95 Trucks & 4Runners 16 09-26-2006 09:09 PM
Completely lost with clutch/tranny problems.. worn86toy 86-95 Trucks & 4Runners 2 06-11-2006 11:54 PM
OD Tranny problems after new mods fondigley 95.5-2004 Tacomas & 96-2002 4Runners 8 09-29-2005 12:19 PM
1988 V6 auto having a hard time getting into OD! HELP! Ilovemountains 86-95 Trucks & 4Runners 12 09-28-2005 04:29 AM
auto t handle w/od removal ? MY024runner 95.5-2004 Tacomas & 96-2002 4Runners 0 12-30-2003 02:57 AM
2009 InternetBrands, Inc.
