auto shifter
auto shifter
I was wanting to know if there was any way that you can remove the gear shifter handle and the auto 4x4 shifter handle for a aftermarket one.
Not really, there is the OD on/off button in the main shifter, plus there is the little lock mechanism. It is a fairly complex little device. I couldn't even figure out how to take it apart when I was looking at it so good luck with that.
Replaced mine with a 2wd 4Runner shifter just because I liked the look and feel and because I could. A bit of a pain to install though, had to cut the OD wiring, solder and heat shrink the splice, and drill new attachment holes.
I think the LandCruiser shifter would work too, a bit larger though.
potatopants
09-15-2015 06:26 AM
May-39
09-06-2015 01:05 PM
