aussie lockers?
Old 07-31-2008, 12:06 PM
lotalucas's Avatar
aussie lockers?
I'm looking at lockers but i really don't make much money. I was looking at aussie lockers and they seem pretty reasonable in price and they say they do the job well but that's from reports off the site and i don't always trust the reviews from the site that's trying to sell the product. (http://www.aussielocker.com/item.php...0/320002/.html)
For anyone out there that has one or has heard anything about them what do you think. Is this locker worth the money or should i wait and save up for somthing else.
Old 07-31-2008, 12:12 PM
axekick's Avatar
I have had one for a couple years now. It's noisy nad you do have to adjust your driving habits a bit but you get used to it. It climbs 100% better though so if you do any of that then it's worth dealing with the noise and stuff. I say do it.
Old 07-31-2008, 12:19 PM
904_runner's Avatar
There is also lockright which is techniqually the same thing.
I have a lock right and just like axekick said, you have to adjust your driving a little but you get used to it.
Look up matt16, he did a full wrightup on his aussie
Old 07-31-2008, 12:20 PM
lotalucas's Avatar
what kind of changes did it cause on the road? Are U-turns still doable?
Junkers88's Avatar
I put one in about a month ago and really like it. As axekick says it makes a little noise and will make you adjust your driving habits a little, doesn't take long to get used to though just be sure and put 85w-140 gear oil in it to help stop the lurching around corners and the ratcheting sound when it unlocks.
I just got past my break in period so I can't vouch for them off road yet. But I'll post up as soon as I get a chance to beat the hell out of it.
Old 07-31-2008, 12:25 PM
904_runner's Avatar
Off road is Awesome!!!!
And yes you can still turn, you just have to be easy on the throttle during the turn, or coast.
Old 07-31-2008, 12:42 PM
lotalucas's Avatar
sounds like a good investment. Has anyone had anything bad to say about it. right now it sounds like it's deffinetly what i want to buy. any difficulties with install. I really havn't ever taken a differential apart. I heard one guy say that he had to grind the bell housing a bit to get it in.
Old 07-31-2008, 12:45 PM
904_runner's Avatar
Well is yours a 4cyl or v6?
I didn't install mine personally, i had it installed by some guy when he was rebuilding my diff (bearings were shot).
I don't have anyting bad to say about them some things to consider:
On slippery surfaces it will spin out easier if you force it.
Sometimes will make the truck learch around sharp turns if you are not easy on it.
People will give you looks in parking lots like your truck is broken when they hear it, but i like seeing their faces
Where are you planning on putting it? Front/rear/both?
Old 07-31-2008, 01:19 PM
TORTIS's Avatar
they are the best bang for the buck. you won't regret it a bit.
Old 07-31-2008, 01:59 PM
Matt16's Avatar
Look in my signature for a review and discussion. I think it will answer your questions. Its more of a plus that a disadvantage for mixed driving.
Old 07-31-2008, 02:15 PM
Beaniam's Avatar
I won't get into the install details as there are plenty of write ups if you search but I will add if you're doing it yourself and it's on a 4cyl rear stick the ring gear in the oven at 220 and leave it there until you're ready to put it back on your carrier. It will drop right on with no effort and allow you to line up the ring gear bolts easily until it cools off.
Old 07-31-2008, 02:48 PM
Jay351's Avatar
I have a lockright, it is similar in design, some say the aussie is better... In anycase, its great! You hardly notice it once past 5mph, infact once past say 20, its completley transperant... unless you are running a high hp engine
Look at Matt16's write up. You won't regret buying one
Old 07-31-2008, 03:00 PM
Fossilized
Staff
dropzone's Avatar
probably one of the best sites to check out http://gearinstalls.com/, Zuk has a ton of write ups on installing AUssies. I would have loved detroits but for the one the price of one I was able to get Front and Rear Aussies
edit: the oven method works great
Old 07-31-2008, 03:36 PM
toyNG's Avatar
Quick question: Is the Aussie designed more like the Lock Right or the No Slip locker? I've heard that it is quieter than the Lock Right, but how does it compare to the No Slip? I guess that was two questions
Old 07-31-2008, 03:40 PM
Jay351's Avatar
I have heard the no-slip has had alot of failures.... I heard some shops recomended not going with it....
Old 07-31-2008, 11:47 PM
lotalucas's Avatar
yah I have a 90 with a 22re. How does the oven method work. No never mind i'll go to one of the forums
Old 08-01-2008, 12:57 AM
Matt16's Avatar
You don't need to heat anything. The ring gear slips over the carrier easier if you leave the ring gear in the sun, but you can also tap it on with a mallet or hammer and piece of wood.
TheBFA
02-15-2020 06:55 AM
83yotastockR
11
11-10-2015 06:54 AM
Toys4parts
09-26-2015 01:56 PM
toyotasaurus
09-24-2015 03:30 PM
zz_denis
09-06-2015 03:43 PM
Quick Reply: aussie lockers?
