Anything else I should do while I have the intake removed?
Old 03-06-2014, 11:51 AM
87tyota77's Avatar
I am upgrading from a Weber 32/26 to a Weber 38, I went ahead and ordered the entire intake manifold with carb and the de-smog block out kit to clean up the engine. I have to say that taking the old intake off was a b*tch and took me a lot longer than expected because I had to remove so much other crap in order to get to all the nuts. I had to remove all the hard fuel lines that were attached to the intake, remove even the oil filter just to get some extra space.
I am just curious if there is anything I should take advantage of doing while the intake manifold is off? I will go ahead and remove all the emissions before putting it back on, but are there any pointers in regards to putting it all back together? For example, should I reuse the same hard fuel lines that bolt on to the stock intake or is there a better way to run new fuel lines? Any special cleaning I should do? Just curious if anyone else tackled this and has some pointers for an easier install.
Thanks in advance
Old 03-07-2014, 03:25 AM
Romans117's Avatar
You will be much happier putting it back on. Sounds like you have it covered. Clean them ports while your there. Make sure the water jackets are super clean. A real oil pressure gauge is helpful. Why the change in carbs?
Blamalam
03-12-2022 07:34 AM
Doug4320
03-24-2018 10:11 PM
trailgoat
08-13-2015 05:54 PM
Flossy
08-05-2015 05:14 PM
Quick Reply: Anything else I should do while I have the intake removed?
