Thread Tools | Search this Thread | Display Modes |
#26 (permalink) | |
classic example of why I am not going with blocks...
__________________
91 Pickup, 4wd, 22re, stock suspention, rollin on 31s... for now that is... 287 thousand miles and counting... Linkies: YotaTech photos MySpace Quoties: Quote:
| Sponsored Links |
#27 (permalink) |
blocks or not you will still have that problem it is your rear leaf springs they would still bend that way .
the truck is 20 years old you need new springs blocks or not.
__________________
my rigs 89 4runner 1989 4runner v6 5 speed everything factory +4susplift running bfg 31s and a aux gas tank and more aux lights than needed 86 pickup 1986 stock pickup 22r 31.10 BFG ATs flatbed a sad day for the 4runner "One moment of patience may ward off great disaster. One moment of impatience may ruin a whole life." |
#28 (permalink) | |
Location: In the air, on the ground- hopefully makin your cellphone work better.
Quote:
http://www.yotatech.com/f116/ditchin...s-soon-145011/ I just thought that I'd post some pics displaying exactly what blocks can do to an old set of springs.
__________________
Knowledge is that thing people don't have that they hope others do so they can get out of trouble without having to learn anything themselves... It's time to re-claim 'green' as the color we deserve. Vote me as President, write-in candidate 2008.While you're at it, write-out EVERY Senator and Representative you can. join Yotatech chat at http://www.yotatech.com/misc.php?do=flashchat |
#29 (permalink) |
i have lift blocks... i have always had them. i don't have any of your problems and well can't afford new springs even though i really want them.
#30 (permalink) |
I think 1" blocks are ok. That's about it.
__________________
'89 4Runner: 22RE 5spd, 4:10s w/202K, 16x8 w/265-75 MT, Diamond headlights, Aisin hubs, Tortis' custom roll on paint job, Home made bikini, 1" Body Lift, 1.25" greasable lift shackles, TG Sliders, 1.5" BJ spacers, Rust is gone! - SOLD! '00 4Runner: Locked F/R |
#31 (permalink) |
So would you guys reccomend shackles over blocks?
I dont have money for new springs right now, need something temporary Always thought blocks might be better because of the change in center of gravity vs shackles, as far as stability and roll-over goes...
__________________
'88 4Runner - 22RE - 190K - Bone Stock |
#32 (permalink) |
If you can swing the $75 for greasable shackles DO IT. That's what I paid for mine and got about 1.25" of lift. Very easy to install and worked out well because they came with bushings and my old bushings were toast. 1" blocks will probably run you $40, so might as well pay the extra $35 for better flex/art.
__________________
#33 (permalink) |
For an inch or so of lift, or maybe to restore stock ride height, shackles are the best bet since they accomplish the lift and also move the trailing edge of the spring down which conveniently causes the axle to rotate the pinion upwards.
__________________
#34 (permalink) | |
Quote:
Yes, they might sag...but those springs are definetly effed up from axle wrap. Good enough reason for me.....that and the fact that they can spit out on the trail creating unsafe conditions (especially if off camber) Have you guys ever seen a block spit out? It aint pretty and it aint safe.
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#35 (permalink) |
Also, a poorly placed AAL can bend springs like that.
__________________
#36 (permalink) |
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/ and http://www.cngnow.com/EN-US/Pages/default.aspx |
#37 (permalink) |
How about ABC?
__________________
#38 (permalink) |
From looking at the pics, it looks like your add-a-leafs are incorrectly installed and that is what is causing your bent springs, not the blocks. They put blocks in GM, Ford and Dodge trucks from the factory and they do not have any problems what so ever. Blocks are fine if you get the correct ones and not going over 2.5". People buy these cheap Pep Boys blocks and they are cast aluminum which equals breakage. You need billet aluminum or cast steel ones. Lift springs are always better than blocks any day but for a budget, blocks will do.
James
__________________
2nd gen power mirrors for sale http://www.yotatech.com/f109/2nd-gen.../#post50746877 New Tacome V6 transfer case http://www.yotatech.com/f107/sale-br.../#post50755569 Various Toyota truck/4Runner switches for sale http://www.yotatech.com/f109/various...trucks-148139/ |
#39 (permalink) |
Yeah, I agree. I was wondering what the difference was in aluminum blocks. So the billet are stronger than the steel, but the cast are the cheapos huh?
__________________
#40 (permalink) | |
Quote:
![]() looking closer it is definitely the add a leafs causing the bending. The blocks just compound the problem. The add a leaf is thicker than the leaves in the pack. It is NOT staggered correctly. The stock leaves are bending right at the edge of the add a leaf. I have seen it happen many times
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand Last edited by dirtoyboy : 05-14-2008 at 07:50 AM. |
#41 (permalink) | |
Quote:
Good deal you are getting a squared away. My '81 came with 3 or 4" blocks in the rear, they suck. Have got the full Trail Gear 5" kit going in soon...
__________________
~Robb '81 Trekker SR5 B4Runner Build '89 Tercel 'Project Beater Gas Saver' PIRATE TOYOTA FAQ TREKKER Forum LINK TO ONLINE FACTORY SERVICE MANUALS Wheel Responsibly, Don't screw it up for others... Last edited by ocdropzone : 05-14-2008 at 08:08 AM. Reason: redundant statement and YT seems to be moving slower today |
#42 (permalink) |
Im with the rest of the gang in saying that your AAL i whats causing it, compounded by the blocks.
New leaf springs with a mildlift and shackles are what I would do.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#43 (permalink) | |
Quote:
__________________
