Thread Tools | Search this Thread | Display Modes |
#51 (permalink) |
Oh, and he has the AAL installed correctly. Im running a procomp short style (UGH!) AAL, they call for it to be installed between the overload and biggest spring.
And my springs are starting to do that too! Time for 63" chevys ![]()
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 220,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace| Marlin armor | Amsoil synthetic drivetrain fluids http://www.cardomain.com/ride/2572486 |
#52 (permalink) |
Location: Climbing cell towers- the deadliest job in America
Thanks, Jay351.
For some reason, I knew the AAL's were installed properly... maybe it was because I'd installed a set on my 91 2wd and they go in the same way? But I digress.... Just got my new springs in to replace my blocks. The thread is over here: http://www.yotatech.com/f116/ditchin...s-soon-145011/
__________________
...relax and rest assured: my name is not allan. Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan. See, I'm being green. |
#53 (permalink) |
umm... me name's kirk- you can use that.
__________________
#54 (permalink) | ||
Location: Dig the Mr. A bobble-head....fool!(..umm...that's ALLAN..yeah)
I like Abe, personally.......as a "nickname", that is.
__________________
Matthew Quote:
Quote:
For more details..http://www.yotatech.com/f116/22re-oi...l#post50799319 And, join the DeathCougar Quotes Fanclub today, and receive a free mohawk!!! WARNING: Eating DeathCougar quotes leads to severe constipation* |
#55 (permalink) |
I thought ABC was perfect, but Capt. Kirk works too.
__________________
Dale 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#56 (permalink) |
When i got my runner it had 3" lift blocks, took those out for 5" springs. A friend of mine who has a Ford, has 3" blocks, went off roading and the blocks shifted! result, stuck rig on the trail with the axel twisted.
#57 (permalink) |
Location: Canada at the moment but Thailand is home nowadays...
The AAL's look fine to me. They just look strange because the main leaf pack is flattened out on the AAL. Usually the upper pack is "U" shaped and it only comes into contact with the flat AAL under a serious load.
And it does look like the blocks didn't necessarily cause the problem, but may have compounded it. It the springs were not shot, everything would have been ok. In any case, its a good contribution for discussion. Thanks ABC, or ABE, or whatever...
__________________
Only $250 for a full set of offroad Fender Flares! 89-95 Toyota Pick Up --- 95-04 Toyota Tacoma
#58 (permalink) |
I'm usin' blocks in my build .. if done correctly .. you should have no problems ..
as stated above .. the spring sag has NOTHING to do with the blocks .. it's just poor maintanance . you need to look after you junk better !!
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum |
#59 (permalink) |
Do you have something constructive to say or are you just defending what you believe to be correct in spite of photographic evidence to the contrary?
__________________
#60 (permalink) | |
You know whats better than leafs sitting on blocks? Coils sitting in the bumpstops over the leafs, sitting over blocks. Come on, tell me I wasn't the ONLY one to have done this...
![]() On a serious note, honestly, I truly don't mind a small block in the rear, but what irks me, is those folks who run blocks up front! ![]()
__________________
Toyota 84 PU: Killed in Action - Pending (Give it time, it'll happen) Toyota 89 4R: Killed in Action - Dukes of Hazard'ed / Evil Knievel'ed Toyota 96 PU: Killed in Action - Tire blow-out induced roll over Some folks call me a crazy redneck. I prefer just Clint. Quote:
#61 (permalink) | |
Quote:
I've been runnin' blocks for years .. and 12 years on one rig .. and now doing another build .. (lost count of the trucks I have built) I have been building TOYOTA trucks since /81 .. whats your pedagree ? I can talk from experance .. my latest build , USING BLOCKS http://www.yotatech.com/f114/1st-one...-build-131775/ .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum Last edited by slacker : 05-17-2008 at 05:50 PM. |
#62 (permalink) | |
Quote:
*edit- And I am going to add that I am currently working building cellular and other wireless communications facilities, including cell sites and radio/tv towers. The pay is 3 times better. I take home, hourly, what most repair shops charge the customers for labor. So, care to address my question: do you have anything constructive to add to the conversation? Put your 'pedigree' to the test. Here's an example- you allege I don't take care of my 'junk' (rather a rude comment since you neither know me nor my 4runner)... so what should I have done differently? Here's another example- you say that the sagging springs and blocks have no affect on each other. Why?
__________________
...relax and rest assured: my name is not allan. Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan. See, I'm being green. Last edited by abecedarian : 05-17-2008 at 06:11 PM. |
#63 (permalink) |
well .. in my opinion ..
springs should have been replace a long time ago .. we all know of the dredded rear spring sag of the 4runners .. as for the blocks .. wether sitting on the OE pirch or a block .. there is almost identical spring "foot print" on the mounting surface , actually better on a block , so that point is irrelevent . other the spring "wrap" , which your runner is not equipt to exert.. there is no identifying cause to blame this spring failier on the block .. explain your reason for blaming it on the blocks please ? .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum Last edited by slacker : 05-17-2008 at 08:13 PM. |
#64 (permalink) | |
Quote:
Fast forward 1 year- my other projects, an '89 Celica GT and a '72 Firebird are on hold so I order the springs and take pictures showing how 1 year of driving on weakened springs and 4" blocks could affect things. All other things being equal, the only thing changed on the rear was the addition of the blocks and the wheels/tires. Now for the 'newtonian physics' part of the story. With the axle bolted directly to the spring pack, the torque seen by the springs was managable, obviously, since the springs were not bent/wrapped. Being that you've worked on trucks before, you know that there is torque from acceleration and deceleration. It's something every vehicle that moves does- that's what moves and stops a vehicle: torque is applied for acceleration and absorbed for deceleration. That torque can induce that thing called 'axle wrap'- the primary reason many people install ladder bars or traction bars- to keep the spring from wrapping up and binding the u-joints or to stabilize wheel-hop. If you've ever used a breaking bar, or clipped the boxed end of a combination wrench over the open end to extend the leverage, you know the advantages of longer levers acting through a fulcrum. When you consider the spring as the fulcrum, the spring perch is approximately 1/2" thick. Now, you add a 4" lever on the axle and guess what? The torque applied to the spring mounting surface increases proportionately to the tune of approximately 8 times more than the perch alone due to the fact that the block is 8 times 'longer' than the perch. You've increased the mechanical advantage the axle has over the spring. Now, add in the add-a-leafs which extend approximately 6" to the front and 8" to the rear. You are then distributing the torque through the comparatively stiff add-a-leaf to the points at ends of the add-a-leaf where it contacts the spring. So now it's not simply a matter of the axle wrapping the spring, it's the axle torquing the lift block and transfering that force through the the add-a-leaf to a well-worn spring. Imagine what would happen without that distribution of torque away from the axle mounting point. So my point in starting this thread was to show the possible outcome of using lift blocks to compensate for the 'sagging' rear end most stock 1st gen 4runners, and many pickups with shells or toolboxes- well any vehicle with leaf springs for that matter, can develop. Feel free to look at the pics at the start of the thread. They display exactly what I'm describing- the main leafs abnormally tweaked by the AAL's due to the torque imposed by the lift blocks. The springs were worn, but had a correct, albeit shallow downward arch before installing the blocks.
__________________
...relax and rest assured: my name is not allan. Save the world! Protect the environment!! Conserve nature!!!! Eat a vegetarian / vegan. See, I'm being green. Last edited by abecedarian : 05-17-2008 at 09:02 PM. |
#65 (permalink) |
I understand the therory of leverage and acceleration . your spring wrap would be neglable with stock tires (or 31's) and an open diff . (unless your popin' the clutch , doin' burn outs , and light to light racing )
but again .. in my opinion , the blocks are not the reason for the spring failier .. they may have accellerated your spring issues , because of weak springs .. but the springs obviously were weak in the first place . and I have read the thread .. the whole thread . "Anyone want a good reason to not run lift blocks?" is not accurate .. It should read .. What happens to weak springs when adding blocks . differant strokes I guess .. I would agree blocks alone are not a good thing .. as I have always used a "spring wrap " device along with them .. .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 MY PAGE 2WD fourm I frequent NEW Trekker forum Last edited by slacker : 05-17-2008 at 09:25 PM. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Good reason to go to the dealer | MARSHALLMAY | 95.5-2004 Tacomas & 96-2002 4Runners | 37 | 03-02-2008 08:17 AM |
| Guys, now we have a good medical reason. | Squeebs | Off Topic Talk | 33 | 01-29-2008 02:02 PM |
| A good reason to tow in neutral, not park... | Mason Dixon | Off Topic Talk | 30 | 12-06-2005 06:23 PM |
| good reason to shop at sears | jacksonpt | Off Topic Talk | 1 | 09-17-2003 07:54 AM |
| One more reason to run synthetic | Biohazard | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-11-2003 06:42 AM |
