Anyone with OME Rear 2" lift springs?
So im thinking about the OME Dakkar 2" lift springs for my 1987 4runner. Can anyone out there tell me or have some photos of the lift it puts on the back? Anyone have measurements from the top rim edge to the bottom wheel well edge on the body?
I already know they are awesome leaf springs, but really trying to avoid too much rake. Thanks
i don't know how the wheel wells on a 1st gen 4runner compare to a 3rd gen pickup, but on my 93 xcab i'm at right around 22.5" bottom of fender to center of axle - running OME medium Dakars w/stock shackles for a few years (broken in). when i first installed the leafs they netted 2-3", but after they broke in they are around 2" lift.
I put them on my 88 a few months ago. I had MASSIVE rake in the back. I ended up taking out one of the helper leafs because it was so stiff. If you get them, make sure to get the arb bushings for them. The front eye on the arb leaf is different than stock. I'm out of town for work, but I'll snap some pics of it on level ground at the end of the week. I bought my ome leafs through Amazon because it was free shipping. A set or two show up on there about once a month. I think I paid $250 shipped.
That was the answer I was looking for, HC. Thank You in advance for the pix and if you could measure the distance from top rim to wheel well edge, I'd appreciate it. So when you removed the leaf, did the height calm down? How's the ride? Thanks again.
I will get some measurements and pictures of it on flat ground tomorrow. The truck is over to my father in laws on the lift getting new brakes. It was still pretty stiff after I took out the helper, but it rides nice now. I think the new bushings had to wear in a little. I also used the OME shackles. Removing the helper def. helped with the rake.
I didn't get any photos of the truck this weekend. Well I did, but my phone went through the wash. But I measured the distance from the bottom lip of the wheel well to the lip of my 15" rim and it was 12 1/2".
Here's a older pic of it sitting on pretty level ground. The front end is original with just new shocks.
Wow. Thank you so much. That looks pretty stock...what I'm looking for. To be clear that photo is taken with OME Cs009R's with one helper spring removed? How's the ride feel?
Sorry about your phone.
That's with just the one helper taken out. It rode a little stiff for the 1st week or so, then it softened up. Taking out the helper spring helped more with the rake than the ride. I think it would have softened up with the helper in, but the rear end was so high up, it looked funny. I have cheap Monroe shocks in the back for the time being until I can pick up a set of OME shocks.
I have them on my 4runner as well. I ended up with more like 3" of lift in the rear even after they have settled some. I have bj spacers in the front with the torsion bar turned up slightly for now and still have about an inch to two of rake. I can try to get a pic up later if you want. I do like the ride for the most part. They are kinda stiff on the highway.They do flex pretty well though. I think the rake is a little worse on mine due to the weight on the front.
Last edited by '884Runner; 10-25-2012 at 09:45 AM. Reason: Spelling corrected... stupid cell phone
Thanks!
i know now this is old but did you ever get around to taking those pics?? This is the set up I am am going for on my 88 and I’m trying to decide between cs009r and cs010r cause I want to put a rear tube bumper with tire carrier and Jerry can.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
