anyone have a starter
Old 08-19-2008, 10:33 AM
galloway's Avatar
i need a starter for a 89 v6 im tryin to get my truck working and this is the only thing i haves left. thanks
Old 08-19-2008, 10:50 AM
apalmer1's Avatar
ive got a couple starters but they are from an 85 with a W56. im pretty sure that a W56 starter will bolt into an R150 trany as we swapped tranys on my friends 87 and were able to use the same starter, however i don't know if the flywheel tooth count is the same on the 3VZ as the 22RE.
you should run down to an auto parts store and check ask them what the tooth count is on each of the flywheels for your year and if its the same part number for starters then PM me if you think it will work. im in Bend Oregon so not too far.
Old 08-20-2008, 11:58 AM
galloway's Avatar
ok thanks but i got it working already. thanks alot for the help
ladybugRC
458
08-21-2020 10:41 AM
pickle6415
10-19-2015 08:08 AM
zombie_barbarossa
10-02-2015 10:54 PM
bradahman
10-01-2015 09:24 AM
beltcutter
09-30-2015 06:14 AM
Quick Reply: anyone have a starter
