Anyone has a rear relocated shocks patern / \
Old 01-12-2009, 06:42 PM
Chief_Yota's Avatar
hey guys ,i would love to find somthin on how you mounted your rear shocks,(pics info),i started a setup but just wanna make sure im taking the right path and if there is something i should be aware of!!!
in an angle patern like that / \
if you got any usefull info please let me know!!
Old 01-12-2009, 06:43 PM
scuba's Avatar
Wait....What are you asking...?
Its been done and has been known to give more articulation..
Old 01-12-2009, 06:45 PM
Chief_Yota's Avatar
i know lol im trying to find a post or some pics of that setup ,and usefull info thats all!
Old 01-12-2009, 06:46 PM
4Crawler's Avatar
Here is how I did mine:
- http://www.4crawler.com/4x4/4R_suspe...shtml#R-Shocks
Old 01-12-2009, 06:47 PM
iamsuperbleeder's Avatar
Google much?
I plan on doing the same when I throw on some 2" springs, as well as some U-bolt flippin
Old 01-12-2009, 06:48 PM
Chief_Yota's Avatar
well well 4crawler himself,why didnt ive tought about checking on your website already! lol
Old 01-12-2009, 06:49 PM
jsn_stockard's Avatar
The greater the angle the less effective the shock is, in most cases. You shouldn't get better flex by adding angle, if you do you need shocks with more travel. Shocks are damaged if they are being used as bumpstops, or limit straps
Old 01-12-2009, 06:50 PM
Originally Posted by jsn_stockard
The greater the angle the less effective the shock is. You shouldn't get better flex by adding angle, if you do you need shocks with more travel. Shocks are damaged if they are being used as bumpstops, or limit straps
well at an angle the extended lenth doesn't have to be so long for greater articulation... it's a complicated geometry and engineering thing... if you get it, good, if not, it's hard to explain without some sort of animation or something... but yes they do loose there efectiveness the steeper the angle
Old 01-12-2009, 06:53 PM
Chief_Yota's Avatar
i got some 12 inch travel bilstein 5150,only making that same setup many people did with the rear of theyre rig when doing a Solid Axle Swap,just wa curious about the setup itself ,but thx guys i apreciate
Old 01-12-2009, 06:57 PM
Super your right, I edited. I have seen many people try to "pitch" their shocks on stock trucks. It takes a working knowledge in geometry to figure how to pitch the shock, with the correct susp setup
Old 01-12-2009, 06:59 PM
Matt16's Avatar
As jsn_stockard said, mounting the shocks at an angle effectively reduces the stiffness. 4Crawler explains it very well on the link provided. This isn't a totally bad thing, as you can simply use stiffer shocks to get the same effect and alot of cheap shocks are quite stiff (ie: $30 Procomp ES3000s).
While using shocks are expensive bumpstops is a bad practice leading shock breakage, using them to limit droop isn't really a problem. There is much less force on the extension, and the stock pickups and 4Runners' droop is in fact limited by the shock (without shocks, droop-limiting factor is the parking break cable and break line!). Toyota wouldn't have designed a vehicle meant for off road travel if a wheel couldn't be lifted without damaging vehicle components.
Old 01-12-2009, 07:01 PM
Ok Chief, didn't know what shocks you were planing. Let me know how those shocks work out, I have been pondering those.
Old 01-13-2009, 03:56 AM
Beaniam's Avatar
I have to do this as well. The 12" can 5150's limit my uptravel on the rear with 4" TG springs.
If you don't feel like making something, Sky sells a kit.
http://www.sky-manufacturing.com/new...uct.php?id=131
Yotadawgjr
10
08-23-2015 10:51 AM
terminator
07-27-2015 07:13 PM
Massmayhem247
07-18-2015 05:46 AM
icentropy
07-14-2015 10:23 AM
akaphilly
07-09-2015 02:34 PM
Quick Reply: Anyone has a rear relocated shocks patern / \
