Anyone ever put in a stage 1, 2 or 3 chip into an 88 4runner?
Old 03-10-2009, 01:58 PM
ajaxdaman01's Avatar
Question Anyone ever put in a stage 1, 2 or 3 chip into an 88 4runner?
So I went ahead and bought a cold air intake, a high flow cat and am gettin ready to have dual exhaust installed. Now my question is, should I put in a new chip? My truck is an 88 4runner sr5 with the 3.0 v6. If I do install one of these chips, will there be any quirks that I have to deal with? The chip im looking at is pre-programmed for my truck. I was told by one person that I would have to switch to high octane gas. Is that true? Will I see a noticable increase in horse power?
Old 03-10-2009, 02:04 PM
Elton's Avatar
it prob wont do crap
Old 03-10-2009, 02:10 PM
874runnersr5's Avatar
from what im guessing its one of thoese ebay chips?
my friend got one for his s10 and wow. All it did was mess up his shifting and lost about 10mpg. He only paid 4.99 for it to lol.
Old 03-10-2009, 02:13 PM
fastkevman's Avatar
You are wasting money and time.
Do a search....you will find many threads on the 3.0 V6.
It does not respond well to upgrades that is why people either roll with it stock or swap it out.
Not every engine is high horsepower build-able.
Old 03-10-2009, 02:26 PM
does that mean the cold air intake and duals are a waste too?
Old 03-10-2009, 02:28 PM
Staff
DeathCougar's Avatar
I also would suggest staying away from the chips that companies claim to "Add HP"
IIRC it just causes the EFI system to add extra fuel, without adjusting anything else. All this does in turn is lower your MPG's without giving you any noticable HP gain.
Without throwing a bunch of money at it, the 3.0L is not the best engine to hop up.
Old 03-10-2009, 02:30 PM
ozziesironmanoffroad's Avatar
i got one of those 'pre programmed' chips, and yeah all it did was raise my RPMs and drop my gas mileage. i ended up selling it to a mexican at the local home depot for like 20 bucks.. lol
Staff
The cold air intake is a waste of money, as many members have come to find out. The best mod it seems is to eliminate the silly elbow on the intake, and just let the air come straight in.
The dual exhaust if done correctly can be helpful. But if all you did was add on a cat back fake dual exhaust, you did absolutely nothing.
Old 03-10-2009, 02:37 PM
InternetRoadkill's Avatar
The MAF conversion I tried on my 22RE made a huge difference. Unfortunately, I had to remove it since the electronics wasn't rated for under-hood conditions.
Old 03-10-2009, 02:58 PM
tc
tc's Avatar
Toyota ECU's are notoriously locked down and don't respond to chips or reflashing.
Old 03-10-2009, 03:05 PM
tc, not 100% true, you can play with the ecu a tad bit, but not enough to really do much. so its true, but not... if you want to get technical... lol
Old 03-10-2009, 03:13 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
The 3.0 ECU is locked down almost as tight as Ft Knox. The 22re....there is a lil "play" with the e prom programming....
Old 03-10-2009, 04:55 PM
space-junk's Avatar
the only things you can do for these motors on the cheap, and i have a v6, is the Short Ram intake (there is no CAI for our trucks unless you want a snorkle!!!), get an exhaust system no bigger than 2.25" (and if its gonna be a dual setup, run a smaller pipe with a crossover right in the middle otherwise you lose backpressure and the v6s need it!) and keep doing your regular maintenence(cap, rotor, wires, plugs, etc.)...
you could drop 1000 bucks into the v6 and only net 15hp to the wheels, so i warn you, unless you like being poor, dont hop up this motor...
Old 03-11-2009, 06:50 AM
ok cool you all thanx appreciate the help
Old 03-11-2009, 08:29 AM
rdlsz24's Avatar
And stay away from eBay paper clip "chips"!!
Rob
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Anyone ever put in a stage 1, 2 or 3 chip into an 88 4runner?
