anybody used these auto zone shackles
Old 05-07-2009, 05:03 PM
brunner628's Avatar
auto zone shackles. there 17.99 for both sides. lemme know thanks.
http://www.autozone.com/autozone/cat...questid=421826
Last edited by waskillywabbit; 05-07-2009 at 06:10 PM. Reason: Please do not use general titles per posted sticky
Old 05-07-2009, 05:28 PM
4banginRunner's Avatar
They were on my 79 when I bought it, total garbage IMO, too long and thin with no bracing, shell out the money for REAL shackles that are greaseable
http://www.wabfab.org/products/suspension/shackles.htm
Old 05-07-2009, 05:31 PM
wheatus's Avatar
x2 on the shackles being junk
Old 05-07-2009, 05:40 PM
corax's Avatar
I used these
but I cut them down to stock length when I put on the OME springs and had to drill 18mm holes for the bolts I needed to use with the poly bushings, at stock length or the first bolt hole they should be fine - you can see the one side at the right
Old 05-07-2009, 05:57 PM
brunner628's Avatar
thats what i figured. thanks for the info. i have been looking at those wabfab and had my mind made up on those. came across those today and the "cheap bastard" came out. any advice on the height i should go with since its a coil setup (not leaf)
Old 05-07-2009, 06:54 PM
corax's Avatar
uhhh . . . coil spring suspension doesn't use shackles . . . what would you attach them to?
Old 05-07-2009, 07:05 PM
brunner628's Avatar
see thats what i thought. so in order to lift the back side i need taller coils?? (kinda new to all this)
Old 05-07-2009, 07:11 PM
Yes, taller coils / spacers
Newb Section Mods?
Old 05-07-2009, 07:12 PM
corax's Avatar
yup, longer coils would do the trick but I'll have to tell you to search to find specifics. Mine has leaf, so I don't know the coil tricks.
Old 05-07-2009, 07:17 PM
brunner628's Avatar
power and drivetrain is the easy part. its wrappin my head around this whole chassis/suspension thang
Old 05-07-2009, 07:39 PM
Lummpus's Avatar
How much lift are you trying to get. I have researched it a lot. fj80 coils will lift the rear about 3 to 4 inches. I just got a pair from a guy on the classified section here on yotatech. for only $60. if your only trying to level out the rear sag you can get some coil spacers. I've heard Sedori has some good ones. check out this site I personally haven't ordered anything from here but I have seen good reviews on here.
http://www.trdparts4u.com/MC-CACJ-BBHG.aspx
Also check out the 2nd gen lift guide it will tell you alot
https://www.yotatech.com/forums/f116...-guide-155339/
Old 05-07-2009, 08:19 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
I ordered 2" coil spring spacers from http://sdori.com/, the owner of the company is a member here, elripster.
punks_is_4x4
05-31-2016 06:03 AM
potatopants
09-15-2015 06:26 AM
djpg2000
09-07-2015 10:36 AM
May-39
09-06-2015 01:05 PM
Quick Reply: anybody used these auto zone shackles
