anybody tried the spindal lubricator for ifs
i was just wondering if anyone has made, and tried this out. seems cheap enough to build, but in the write up he mentions pulling the shaft back out of the housing, after pumping in the grease. if you have to remove the bolts and pull the shaft out a little, heck you could grease it by hand.
https://www.yotatech.com/forums/f128...6-95-a-105523/
I bought all the parts to build one....I still need to get the nut welded to the top of the pipe. By pulling back to draw the grease back in seems like it wouldn't be that much...considering you are using the leverage of the end 'cap'...don't know though for sure cause I have yet to try it. Good luck and if you do try it out let us know.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
