Anybody Narrowed a Landcruiser Front Axle?
Old 11-08-2009, 05:51 PM
wrenchtech's Avatar
I'm wondering if anybody has narrowed down an FJ80 Landcruiser solid front axle housing for use in a mini truck/4runner. It looks like they are 63.5 inches wide, compared to 55-1/2 inches for the mini front. I'd like to end up with a housing 60" wide.
Also, are the ball/knuckle ends on the housing the same on the Landcruiser and the mini, so that the outer knuckle will swap? -- Matt
Old 11-08-2009, 06:49 PM
tc
tc's Avatar
With what high steer and such costs for an 80-series axle, you're better off adding wheel spacers or the IFS hub swap to a minitruck axle.
All that said, if you have the skills, shortening the housing wouldn't be much different than a cut/rotate job.
Old 11-08-2009, 07:00 PM
JonnyBoy's Avatar
Then custom length shafts?
Old 11-08-2009, 07:09 PM
peow130's Avatar
I could see custom length shafts being pretty spendy..
Old 11-08-2009, 07:42 PM
drew303's Avatar
I'm sure someone's probably done it but to shorten them for use under a mini/4runner is counter-productive. If I'm not mistaken the internals and hardware is the same? Just wider/longer. They both use the same thirds.....
Wheel spacers, bobby longs and a FJ80 high pinion.. you're set =)
Old 11-08-2009, 08:14 PM
wrenchtech's Avatar
I forgot all about the IFS hub swap. Sky Off-road made a kit.. Looks like it's an improvement over wheel spacers anyway. And it might help with wheel clearance for bigger calipers.
oldirtydirt
02-23-2020 09:30 AM
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
Cabell
07-24-2015 12:14 PM
Quick Reply: Anybody Narrowed a Landcruiser Front Axle?
