Any power gain from a high flow cat/ test pipe?
I know that on other cars a test pipe or high flow cat really helps open up the power range and adds power, my 93 4runner is getting sluggish on mountain passes with my 33's. Has anyone noticed a power gain with replacing the cat with one of these two options? Im tierd of getting passed by semi's
You would probably gain a little more power with a new high flow cat and a larger exhaust, or you could go all the way and buy a set of headers to get the most from it. That won`t turn a 3.slow into a power house, but it will help. Also another thing that will help you alot is to regear for the larger tires you have, that`s what`s killing your power the most right now.
yes it will make more power, mostly because your cat (if original) is getting pretty plugged up. but most people would be surprised that a high flow cat and muffler will often make close to, if not as much, power as a straight pipe. i would also recommend regearing.
besides the exhaust its stock with the exception of the swiss cheese airbox mod lol
Poncho0206
07-10-2015 06:21 PM
