anti freeze just leaked out all onto the ground
I just came home from the park, my truck was running perfect, anyways I pull in to my driveway with the window rolled down and I start hearing a really weird noise. I put it in park, pop the hood and get out to inspect what it could be. Anyways I see all my anti-freeze from the radiator spilling onto the ground. I mean ALL of it came out. Then it started smoking like crazy so i had to get the house and squirt it all over the radiator.
Anyways, the leak is from the bottom i know that for sure. So what could have caused this to happen? I have no experience whatsoever on this stuff so bare with me.
Also my truck is a 1988 2WD toyota pickup 22RE.
Thanks,
John
Thanks,
John
Yeah I'd say you blew a hose. In the future, not a good idea to blast a hot engine or anything for that matter, with cold hose water. You could make things a lot worse.
Also another question, is a blown hose the only cause of this? Could it have something to do with the thermostat?
Tell me what I should replace and ill replace it doesnt matter how much the cost is, i just dont want this happening again in the future.
Might as well replace the thermostat if you haven't done it in a long time.
just replace the hose, hopefully it will be fine.
Hoses get old probably why it ruptured
problem
dont take this the wrong way but untill you actully look it is hard to answer your question. It could be the hose ,it could be a seam leak, could be the tstat, could be the coolant faireys
Funny....my first thought was a stray round from a drive-by shooting got his radiator.
Blamalam
03-12-2022 07:34 AM
Tacoma1313
08-17-2015 05:44 PM
