YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-04-2006, 03:31 PM   #1 (permalink)
Ilovemountains's Avatar
Antenna for 1988 pickup needed, dont want Autozone speacial,PN needed!
Hi guys, Im getting started putting my 88 back together after its paint job.. I had to kill the stock antenna to get it out of the fender which was OK because the plastic rod down in the fender had actually just broke anyway! I want to buy another stock antenna or one that mounts like the stock with that support bracket, I installed an aftermarket universal mount on my last truck and it sucked, it just mounted to the sheet metal and did a number on the fender! Does any one have the Toyota PN of the stock antenna or know of an aftermarket that mounts like the stock? A power antenna would work too as long as I can mount it in tight! Thanks again, Matt
__________________
88 3.0 XCab, K&N fipk, Borla cat-back,Magna Flow Cat, Downey frame brace, Downey 2" rear springs, BJ spacers, Aisin manual hubs,B&G Fiberglass bed, extended diff. breathers, Rancho RS9000X 9 way shocks, Rancho RS5000 stabilizer, Brembos & TRD Pads, Revos, Smitty grill and nerf bars, Hella 500s, bucket seats and console, Sony ES head unit, Sony EQ, Infinity Kappa 6x9s Pioneer 6.5s, 10" MTX sub and a Denon 5 channel amp...
Ilovemountains is offline
Sponsored Links
To remove this ad, register today!
Old 07-04-2006, 03:43 PM   #2 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
https://www.1sttoyotaparts.com/partscat.html has them for $36 bucks
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is online now
Old 07-04-2006, 03:43 PM   #3 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Talking
Put a non power oem antenna on my 87 when the power one died. Got it from the dealer. Not all of them had power antennas. Ask Strap22 on YT.
waskillywabbit is offline
Old 07-04-2006, 05:35 PM   #4 (permalink)
gohawks's Avatar
I have a couple of manual ones that I used from Crutchfield.com until I got my power antenna put back together.
The work well. Just go to crutchfield.com and take a look. IIRC it was like $20.
If you can get an OEM one for a few more bucks I'd do that, although the metra one works fine.
As a side note, I think that the manual antenna got better reception than my power antenna.
__________________
1988 Toyota 4Runner SR5 3.0
SERENITY NOW!!
gohawks is offline
Old 07-04-2006, 05:51 PM   #5 (permalink)
gohawks's Avatar
The package I have for the metra product says 44-ty22B.
Fits Toyota Truck/4Runner 1984-1988, Camry 1983-1986, Celica/Supra 1983-1985.
Do a google for 44-ty22B. I see them on ebay usually as well or as mentioned before Crutchfield.com
__________________
SERENITY NOW!!
gohawks is offline
Old 07-04-2006, 07:11 PM   #6 (permalink)
crackerjack's Avatar
I got a neat retro fix for a standard antenna. Found one of those CB antenna that has magnetic base 9.$ at flea market. Took the spring part off then cut the head off a bolt that would fit my base now when I go under tree limbs it just lays over
crackerjack is offline
Old 07-04-2006, 07:53 PM   #7 (permalink)
AKennedy87's Avatar
Send a message via AIM to AKennedy87
I got a power antenna from crutchfield. I think they ed it up cause it was only $10. Check it outt i duno if its still like that.
__________________
1987 4Runner SR5 4x4 - 5spd M/T 22RE - 3" Add-A-Leaf Rear - 31/10.5/15 Michelin LTX A/T's on 98 Tacoma Wheels - Aisin Manual Hubs - Thule Rack System - 12" JL W0 w/ Alpine amp and custom box - JVC headunit
Cardomain
AKennedy87 is offline
Old 07-04-2006, 09:49 PM   #8 (permalink)
fredtheturd's Avatar
Send a message via Yahoo to fredtheturd
power antenna part number for my 90 is 86300-89126...hope this helps...later
fredtheturd is offline
Old 07-04-2006, 10:04 PM   #9 (permalink)
gohawks's Avatar
1990 part # will be different. The fender shape is different than on first generation
__________________
SERENITY NOW!!
gohawks is offline
Old 07-05-2006, 06:36 PM   #10 (permalink)
Thanks again guys you ROCK! They even have the black windshield trim that I want to buy to replace the chrome crap I broke and bent taking off the truck to paint it! SWEET!
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
antenna fix for limited-no fender flare removal needed creekfisher 95.5-2004 Tacomas & 96-2002 4Runners 9 11-22-2008 12:14 PM
86 Pickup Turbo Parts Needed RICKY24 86-95 Trucks & 4Runners 4 10-12-2007 05:50 PM
Looking at an 80' pickup - thoughts needed. Cactice Off Topic Talk 37 12-06-2006 02:13 AM
1988 Toyota 4runner parts needed ASAP bsmi16490 Items Wanted 4 02-12-2006 09:58 AM
Pickup buying advice needed ZeroYota 95.5-2004 Tacomas & 96-2002 4Runners 5 11-17-2004 05:37 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
